Results 31 to 45 of 62
Thread: Heat wrap?
    Default Re: Heat wrap?
    Your not worried about the metal 'rotting' out under the wrap?
    Malicious
    S.A
    i do know what you mean but no im not worried. it is all stainless the only think to be concerned with is cracking but even then it is a minimal concern.
    Toymods Club Member Backyard Mechanic Big T's Avatar
    When i got my turbo manifold coated i recall him mentioning that he could "chuck it in the bath with the rest of the other stuff" (my mani was for a 4 cyl and fairly small) Perhaps that implies they're immersed in the coating before being heat treated?
    This was at Competition Coatings at Granville. Cost $180 incase anyone needs a price comparison.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    S.A
    ceramic coat australia in s.a spray all of their stuff!
    He has a wand with lots of little holes in it to do inside of pipes
    inneresting! would be good to find out more abotu their processes....
    if i still have access to XRD stuff when i get back, i'd love to chuck a bit on and see what it's made of
    what grade stainless do you have... some grades will "sensitize" (from vague memory) around 700-900 ish (yah.. real specific ) and cause embrittlement... perhaps if it is a weldable grade than it is ok...
    hmm, if he has a wand with little holes, then it definitely isn't thermal or plasma spray process.... they must just be spraying on a slurry of sorts and then sintering it after to form the coating....
    S.A
    my old dump pipe was 316 grade and coated but not wrapped.
    the new one is 304 grade and has been migged together. the reason i chose 304 is cause i didnt have much of a choice as 3,5 inch pipe and bends i couldnt get in 316 grade.
    I dont think ill have probs with cracking . I have had probs in past but a flexible joiner after the dump soon fixed this! ( you learn by your mistakes)
    If you are interrested i can call him and find out a bit more about his process. He is a top bloke and would have no probs telling me
    Oberst Koi-Master Backyard Mechanic
    Quick question.
    I have 20v primaries and secondary pipe ready to go onto my gze, would you guys recommends getting both the primaries and secondary done? The secondary has a flex joint but i'd assume they can work around it?
    T'ville, QLD
    yah i know i will kill it if i remove it, but im seriously thinking about a 3tgte conversion, when some dosh rocks up at my door that is
    2T out 4A in....
  9. #39
    Toymods Club Member 1st year Apprentice
    Sydney, N.S.W
    Ceramic coating is definitely the way to go along with a proper heat shield... I was informed by the exhaust shop that yes over a long period of time it can wear out your extractors, dump pipes etc by containing the heat...The wrap becomes hard & brittle pretty quickly from the heat. I re-used some old wrap I had laying around for one of the power steering hoses on my car, the stuff was all breaking up
  10. #40
    Hey TA22 GT, I just had a look at your pics and that ACL sheeting look alright. Hoe flexable is it? Might be a goer for the mani and hot side of the turbos. Not sure if i could utilise it for the dumps tho...
    Malicious
  11. #41
    Junior Member Domestic Engineer TA22 GT's Avatar
    ReQuiem,
    I have the ACL heat shielding on my manifold and dump pipe. Its not that easy to bend but if you take your time you can still get it pretty neat. Its the best heat shield I've seen.
    In my opinion, ceramic coating together with this heat shield is the answer, well it was for me at least....
    This is the pic of it on my 3T GTE
    Simon
  12. #42
    the ACL heat sheilding is the one they sell to FORD for the turbo 6 pots.
  13. #43
    What is that stuff worth?
  14. #44
    Penrith BC
    stewy - PM me you address. ill send you a sample of wrap
    ../delete/ban
    tech moderator
  15. #45
    stew wait till you get home and ill give you a sheet! it is very good heat shielding, its an updated version of conical foil i have been getting from the states for years.
  1. MZ20 (7M-GTE) heat issues again...
    By doobs in forum Tech and Conversions
    Last Post: 04-02-2006, 04:14 AM
  2. Ceramic coated pistons
    By mic* in forum Tech and Conversions
    Last Post: 28-01-2006, 12:42 AM
  3. ffs jza70 heat problems F**K
    By chrisjza70 in forum Tech and Conversions
    Last Post: 04-01-2006, 01:57 PM
