Results 1 to 4 of 4
Thread: Advice Wanted - RA28 Wheels Clearance
    Canberra Celica Group 1st year Apprentice Akaoni (Casey)'s Avatar
    May 2007
    Question Advice Wanted - RA28 Wheels Clearance
    Hey All
    Just a quick query, do these wheels have enough clearance from the struts and chassis or am I gunna run into problems:
    This gap is about 20mm. I couldn't get a ruler in past the sway bar and only just thought of using a tape measure then (DOH!!).
    These are 15x6 at, AFAIK, +30 offset:
    Cheers!!
    Casey
    Akaoni - My Red TA22 - BEAMS Blacktop (On the Backburner)
    Slick - Wife's Blue RA28 - BEAMS Blacktop (In Progress)
    Betty - White Hilux Daily - Stock Awesomeness
    Dot - Black Kluger Kiddy Wagon - Stock and Soccer-Mum-tastic
    Canberra Celica Group - http://canberracelica.org/
    Top End
    Default Re: Advice Wanted - RA28 Wheels Clearance
    should be ok the offset is a little large but looks like it will work
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    I've heard of people running clearances even tighter than this with no reported problems, so you should be Ok. Maybe consider a 5mm spacer on the fronts just to give yourself a bit more room? Looks like worn tires on those rims - you will need to be careful with what you select in terms of width/profile when you need to replace them. Even tires the same specs as you have now but with new rubber will be a bit closer on the chassis clearances.
    May 2007
    Thanks Zammo and ta22fan!!
    These tires are actually bigger in diameter than the ones I'll put on, which should open the clearance to the chassis up a bit (or equalise the difference in wear).
    Hopefully there isn't much wear of the side walls though or the clearance will get worse.
    Casey
  1. 18rg ra28 ke70 Xmember Sump clearance
    By Pagie84a in forum Tech and Conversions
    Last Post: 10-07-2012, 08:41 PM
