Cool, thanks. One less thing to worry about.
I went and picked up the rear discs today. He removed the right one in one piece but removed the left one in individual pieces (the first side he removed before deciding it was easier to drop the whole subframe). The arms that use the really long bolts were still attached to each of the knuckles and looked like he had tried to remove them as there were hammer marks on top of the threads, so the nuts wouldn't thread on. Didn't bother me though because I wanted to use my existing arms so I didn't have to worry about getting another wheel alignment, but good God, trying to remove those bastards wasn't fun........
The long bolts were seized in place and wouldn't budge whatsoever. We were whacking the hell out of it with a hammer and spraying all sorts of lubricants on it but nothing was working. After a couple of hours of whacking and a couple of broken ratchets later we finally ended up getting one of the bolts out. Fortunately the other side came out easier, but certainly wasn't a walk in the park. So now I finally just have the rear knuckles complete, without any existing arms fitted.
My next problem was reassembling the one side that he had removed in individual pieces. It was pretty straight forward since all of the bolts were included, but I couldn't figure out for the life of me how the caliper slid over the disc with the brake pads in place. I couldn't seem to get enough clearance between the brake pads for it to slide on without using excessive force. Not wanting to damage it, I decided to leave it alone before I stuffed something up (first time I've ever played around with brakes). Planning on heading to Midas with them tomorrow and just asking them to do me a favor and put the caliper on for me (and also check the other side to make sure it's installed correctly). Then I'd be ready to install the brakes sometime in the next couple of weeks.
I got the brake proportioning valve from the Levin. Was bloody awkward with the engine installed though, because the 4A-GE 20v's have much larger plenum then the 4A/7A-FE engines. Got there in the end though. Even grabbed the handbrake just in case (although it's a different colour than mine so I'll just have to switch over the cable if need be). I'll keep you posted as to how I get on. Here I was thinking that this job would be simple, but nothing on my car has been lately so I should have seen this coming![]()
