Quote Originally Posted by lexsmaz View Post
Also make sure that the ignition timing is correct & you are getting Mechanical advance from the distributor, but more importantly check that the Vacuum advance is working as the vacuum advance main purpose is to improve fuel economy on light throttle cruising ..
Will definitely check both the timing and the mechanical advance Lexsmaz. The mechanical advance is a big issue if it's dodgy, but hopefully all the other little things added together will make a difference.
