Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: 1UZ ECU - How specific are they to each engine/model - LS400/Celsior
    Default Re: 1UZ ECU - How specific are they to each engine/model - LS400/Celsior
    hi,
    yeah i wondered how the fan control worked between the hydraulic fan and the electric fan.....
    So, the only ECU i've managed to find so far for a 93/94 was a cali spec ls400. Finally got it last night but it wouldn't even start the car (not really surprised, more frustrated still) but didn't have any time to diagnose. So i'll do the usual spark timing fuel check today. To me it sounded like it wasn't getting fuel so maybe the cali setup was a little different.
    I've got my eye on one in NZ, so i'll probably buy that as well. Money money money, must be funny,.......
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    I didn't think any had electric and hydraulic?
    The Celsior has hydraulic and no electric, where as the LS400 has electric for the aircon, and viscous for radiator cooling.
    Feb 2012
    Quote Originally Posted by roadkill View Post
    Hi All,
    Now, so far i haven't been able to find anyone with the same part numbered ECU. I have an 89661-50180.
    bEn
    i have the same model ECU - but i need it so you can't have it.....sorry! good luck with sorting out this annoying problem!
    “Speed has never killed anyone, suddenly becoming stationary... that’s what gets you.”
    Jeremy Clarkson
    yeah, i mean that there is probably something different in the ecu to control the electric fan vs controlling the hydro fan.
    Quote Originally Posted by CrUZida View Post
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Junior Member 1st year Apprentice slipway NZ's Avatar
    Apr 2007
    Brisbane, QLD
    Had the same problem with my LS, was the ecu. Im 100% sure it wil be your problem. In NZ we will have a ecu for you
    so I fiiiiiiiiiiiiiiiiiiinally managed to get an ECU for this. It's actually a celsior ECU, not an LS400 (different part no) but it works! Hurrah! I haven't driven it yet but i can floor board the engine and it red lines, doesn't cough splutter or anything. Just runs as it should! Would love to know what the difference actually is between the two. I've still gotta take the sump off of the auto, re-seal and fill it back up before i take it for a spurt.
    So, anybody want a somewhat stuffed LS400 ECU?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    Nov 2011
    I think that I know which Celsior ECU that you have got. Late UCF11 which as you've found has better fuel and ignition maps. Pinouts are pretty much the same and these ones did have another ECU for the hydrofan so you shouldn't have any probs with code 56. Just remember to run it on 95 octane fuel or better
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
  8. #38
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Whats the part number on this new ECU?
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  9. #39
    the old ecu for the ls400 was 89661-50180 and i replaced it with a 89661-50170. I can confirm too that the US spec ls400 ecu does not work. Doesn't even start the friggin car.....
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  10. #40
    Nov 2011
    doesnt the us spec motor have the igntiion outputs of somehting swapped over
    i know this is the case with 95 or 96 or 97 ls400 ecus
  11. #41
    nfi man. When i got it i just plugged it in and crossed my fingers. It would crank but not even a hint of it starting. I had a look into the pinouts of it all and there were a few that were different so hence didn't go any further with it. Since then it's friggin disappeared. Have no idea what i did with it.....
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. 1uz, Celsior, LS400 help needed
    Last Post: 21-10-2009, 07:40 PM
