Page 4 of 18 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 270
Thread: MRP 7age/9age 1900cc Stroker Kit
  1. #46
    Jul 2007
    Default Re: 7age/9age 1900cc Group Buy!
    I'm going to enjoy revving AND boosting the tits off this thing by the looks of it
  2. #47
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Cool! Will CP keep this on file in case (heaven forbid) someone has an 'accident' with their pistons? Of course I'm putting my kit in a 16 valve.
    Bazda, I have some Atlantic valves (32.5mm, 27.5mm), will 16V's cutouts be ok for oversized valves?
    == 4AGZE SC14 Supercharged ==
  3. #48
    Jul 2008
    Auckland
    Quote Originally Posted by nick.parker View Post
    Will need to make your cut outs larger. Noted down!
    To get replacement pistons you will need to go through us.
    Now 9AGTE 410kw atw
  4. #49
    Jul 2007
    yeah replacement pistons would be good to have available in case i get a bit too happy with the boost
  5. #50
    Jul 2008
    Auckland
    No issues! we will be trying to keep stock of these kits in the future!
    Now 9AGTE 410kw atw
  6. #51
    Feb 2010
    Auckland
    Quote Originally Posted by Bazda View Post
    Hey Baz
    Re: larger valves.. is there anything wrong with running a larger cutout using a standard size valve? I'll be running standard size to begin with but may swap to larger ones in the future. I just thought it may be easier to allow for that option now rather than replacing/recutting pistons later? just a thought
    (ignore me if this applies only to high CR NA 16v pistons, and the turbo option runs non interferance ah-la 4agze )
    Oh.. and I'm gonna need some serious alone time with that crank, that looks well impressive.
  7. #52
    Mar 2010
    Mississippi
    Just a quick question, will these kits come already balanced? Or will I need to take the parts to a local machine shop for balancing?
    thanks,
    wrenchdad
  8. #53
    Feb 2010
    Auckland
    Quote Originally Posted by wrenchdad View Post
    thanks,
    wrenchdad
    I could be wrong, but would you not need to get it balanced with your clutch/flywheel and crank pully ??
  9. #54
    Mar 2010
    Mississippi
    Well, I am hoping that it would be balanced as those parts are already balanced from the factory. Plus they are still in use right now and I was hoping to have this new stroker put all together then swap out the old
    20v engine over Christmas holidays while I am on vacation. BUT if that's not the case then I guess my car will have more down time that I had planned.
    wd
  10. #55
    Jul 2008
    Auckland
    Our parts will be balanced from the manufacturing facilities.
    You will need to balance it all up with your clutch and pressure plate plus crank pulley. That's the only TRUE way to do it.
    You can send us those items and we can balance it for you..
    You can just bolt up and not do anything but I would advise a full proper rotating away balance be done.
    Now 9AGTE 410kw atw
  11. #56
    Mar 2010
    Mississippi
    Ok, I got it, I will just have to change my plans on how long my car will be down, no problem. there is a local machine shop that can do the balancing.
    thanks
    wd
  12. #57
    Jul 2008
    Auckland
    Just saw a guy on Facebook trying to sell a 4age 1.8L stroker kit.
    I asked why not just use the 7a and save your self alot of money. His reply is the 7a cant rev.
    Then he goes on to say he got custom made a 4age 85mm stroke crank LOL. The 7a is 85.5mm. So he basically made a 7a crank just in 4340.
    Turning the 4age into a 1.8L means its effectively a 7a but with short rods making the rod stroke ratio well down in the 1.4:1 range.
    How that will rev better than a 7a... no idea.
    Now 9AGTE 410kw atw
  13. #58
    Jul 2007
    people be stupid.
    also just thought of something else.. if we want to run oil squirters on the &a block will these pistons accomodate for that? ie are the skirts short enough, or do they have cutouts, so that they wont foul on the squirters if we were to go down that path?
  14. #59
    Jul 2008
    Auckland
    people be stupid.
    Already covered. If you look at the skirt shape we dont need "cutouts" to clear oil squirters.
    Its shaped to clear.
    Now 9AGTE 410kw atw
  15. #60
    Jul 2007
    good stuff
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 9age??
    By Bazooka in forum Tech and Conversions
    Last Post: 06-10-2012, 08:44 PM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
