Results 1 to 6 of 6
Thread: ECU reset after AFM change
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default ECU reset after AFM change
    Just wondering, when swapping an AFM to another, is it necesary to reset the ECU for it to run correctly?
    Thanks!
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: ECU reset after AFM change
    It can't hurt. I would imagine that the ECU could have "learnt" the old AFM and the new AFM may differ slightly. But then, it may compensate for the changes anyway.
    The only way to tell is to try it for yourself
    Junior Member Domestic Engineer 1200det's Avatar
    usually a good idea to disconnect the battery when unplugging electricals like the AFM and in turn this will reset the ECU anyhow , So why not hit 2 birds with 1 stone
    essentially no you wouldnt need a ECU reset if its a standard AFM replacement , but saying that a ECU reset and learn is always a good idea every now and then anyhow.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Ok. Thanks guys. Ill reset it, via battery disconnect
    Kind Regards,
    Kurt.
    New Zealand
    so why does a factoru ecu need to be reset?
    i have yet to EVER see any proof its needed or makes any difference.
    they are made to run within rather limited parameters. if they could "learn" why do we need aftermarket ecus?
    They have to be able to compensate for variables like fuel, air temp etc. These are dynamic so the ECU must change the timing etc to compensate.
    Every time I have reset the ECU, my idle jumps up just past 2000 on the first start, while afterwards it does not.
    Above all else, an ECU reset is to remove the error codes
  1. boosted 3rz with stock ecu
    By BeRad in forum Tech and Conversions
    Last Post: 24-05-2006, 06:15 PM
  2. Can the ECU get a fault wrong?
    Last Post: 28-02-2006, 12:28 AM
