Results 1 to 13 of 13
Thread: ECU Tuning...?
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    Default ECU Tuning...?
    I have my lux, and i have a wideband sensor coming soon, and i wish to have a go at road tuning my microtech mt8s.
    Anyone have some good guides out there on how to tune, and what kind of procedure is best to use?
    Like things like, tuning cold start, whats the best A/F for which rev limit/load etc etc, the finer points.
    Default Re: ECU Tuning...?
    www.mrcontrols.com has some info, whether or not it will be relevant, but it will give u a basis!
    from what i can gather u will only be able to get low load sites on the road, which is fine if u are tuning for driveability
    27.90s @ Esses Hillclimb
    Rosewood
    Quote Originally Posted by Roundy
    I can get high loads as well, beauty of the hilux is the ability to load it up with stuff on the tray and go for a drive
    bahaha indeed...i never woulda thought of that!! lol
    Set the idle to whatever feels right ie. if it hunts put more fuel in until it doesn't. Don't go too rich though.
    Does your microtech come with a base map for a boosted engine? If so, wait until it warms up before you adjust anything. Then use the mix trim to compensate for the entire map (incase you have larger injectors than stock)
    Then I would bet checking the pump 1 & 2 settings to see how it reacts to more or less fuel on acceleration.
    You should be aiming for somewhere between 13 and 14.5 or so for light acceleration.
    The microtech will have the t-rpm map done and you can see how it advances as the rpms rise. You have to check the t-map map to make sure that it is retarding as it makes boost. Do a search for a good baseline figure.
    Also check out www.microtechefi.com forums.
    Once you are on boost should be aiming for around 12:1 IMO as that is safe. So you want a nice smooth AFR line as it comes onto boost from 13ish to 12:1.
    Then you will need some sort of knock detection device. I have inputted my knock sensor into my wideband to datalog it but I am unsure how it will work as I haven't tested it yet. I also have a Jaycar Super Ear Kit which is great.
    You want to be listening for any knocking noises. http://home.netcom.com/~bsundahl/kno...nockSounds.htm
    If you know the theory of how an engine will respond to different changes then I don't think tuning is that difficult. I am also going to be using a g-tech for some fine tuning later on with the 0-100km test (as long as I don't spin too much) as well as the datalogging in the microtech to see how different timing maps affects spool up etc.
    Hope that helps.
    Definitely check out the microtech website though.
    QUICKEST 1JZ'S IN OZ
    Rosewood
    Thanks chris thats the kinda info im after.
    The map in my lux is already tuned, but i want to go in and start fine tuning it to take a bit of fuel out for cruise etc.
    From what i've gathered with a few of my own questions on microtechefi, cruise is best to be 14.7 to 13 from -30 to 0 and then from 12 in the midrange and then 11.5 for top end safety.
    I've devised up a knock circuit which im going to trial and see if it works. Other then that ill be buying a superear down the track as well.
    Oh well that info can be for anyone else that may need it then
    FIne tuning is easy as long as you have the tools required to measure differences.
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    Quote Originally Posted by chris davey
    So does this "super ear kit" actually help you detect pinging with your own ears? thats really cool if it does, especially if you can detect it early - before you would normally hear it otherwise
    found the jaycar description:
    http://www.jaycar.com.au/productView...Max=&SUBCATID=
    I am yet to use it in practice as my Rona isn’t quite drivable at the moment but very soon it will be.
    I have tried it on my daily driver Camry and you can hear everything. Where I had it mounted was not ideal and for some reason this car has abnormally loud injectors but it was very easy to hear what was going on and I had it on the lowest volume possible as otherwise my ears would be ringing
    It is very sensitive and it has a frequency booster also but I am not using it as it seems to get some interference when I turn it on and normal is fine anyway IMO.
    So as long as you know what sounds you are listening for then I think it will work very well. It is basically the same thing as the dyno tuners use when they put the headphones on. For $25 it is a bargain too!
    I will mention that I don’t think it is easy to put together but I am useless with electronics so Chuckster put mine together for me and did a great job!
    ahh so its a self assembled thing, cool! sounds like it might be a bit of fun, might even have other uses besides listening for detonation
    Yeah comes as a kit to put together. Everything required except headphones and some shielded microphone cable for the transducer.
    And yes, my dad is using it to find blocked pipes (he is a plumber) Told him he has to get his own now
    so the super ear ki is like the old 'chassis ears' then. I can pinch one of those from work. they are awesome. the one we have has 8 channels on it too so can hear for a lot of different things
    yep 10 char
  1. Replacing 7mgte ecu
    Last Post: 17-04-2006, 09:43 PM
  2. TVIS not engaging due to ECU?
    By phrostbyte in forum Tech and Conversions
    Last Post: 03-03-2006, 11:39 AM
  3. Can the ECU get a fault wrong?
    Last Post: 28-02-2006, 12:28 AM
  4. Replies: 5
    Last Post: 13-02-2006, 09:34 PM
  5. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 10:31 AM
