Results 1 to 2 of 2
Thread: 18rg ignition timing/maps wanted
    Mar 2012
    Default 18rg ignition timing/maps wanted
    Hi guys,
    After gettin my new 18rg up and running i want to get some decent performance out of it so ive decided to update the outdated points driven ignition timing. So i've decided to replace it with a standalone electronic ignition kit, which requires me to manually a map to run the car.
    So i was wondering if anyone had an ignition map for an 18rg engine that i could use as a start point or if anyone knows so of their timing points with the original distributor?
    Im currently using weber carbs and my initial advance is up around 20degrees and i feel this is a bit high? any second opinions would be excellent on this
    Default Re: 18rg ignition timing/maps wanted
    Jump into the tractor engin thread, I posted up my old ignition maps there I think.
    You will need to lock the mechanical advance in the distributor though for this to work.
    20' base advance is too much imo, should be around 10-12'.
    Find those posts by me and you will get a good start point.
    ...... butt scratcher?!
  1. Ignition maps - show us yours
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 09-07-2012, 06:26 PM
  2. 1jz ignition maps
    By 240jz in forum Tech and Conversions
    Last Post: 25-04-2007, 04:14 PM
  3. timing maps/strategies for old-school turbo engines
    Last Post: 18-03-2007, 07:21 PM
  4. 3SGTE - stock fuel/timing maps - JDM ST185
    Last Post: 28-08-2006, 05:54 PM
  5. 3SGTE - stock fuel/timing maps - JDM ST185
    By thechuckster in forum FAQ
    Last Post: 28-08-2006, 11:30 AM
