Results 1 to 10 of 10
Thread: Carb Manifold Manufacturers - any apart from Lynx or Redline ?
    Sep 2011
    Default Carb Manifold Manufacturers - any apart from Lynx or Redline ?
    ive been searching the lynx and redline websites, and they dont seem to touch 6 cylinder toyotas.
    only the 4's.
    are there any other manufacturers of intake manifolds (to suit carbs) that i would be wise to check out?
    or would it be a case of a custom job for an M motor.
    1974 Crown SE -- the "kandy" crown
    1971 Ford Capri GT -- 624rwhp at 25psi ... 1000kg race weight ... 4L with T51
    For Sale: 6x 1000cc Rochester 2JZ top feed injectors ($600 ono) & JIC dampening adjustable coilovers JZA70 $800
    Nov 2011
    Default Re: Carb Manifold Manufacturers - any apart from Lynx or Redline ?
    From some searching of known suppliers back from the days of dyno tuning and heaven forbid ownership of a Rover SD1 Vitesse and prior to that a Vauxhall Ventora 3.3 (which aside from a twin CD stromberg manifold anything else had to be custom made) I'd say you'd be looking at a custom job. What are you trying to do?
    His. 2005 GRJ120 Prado VX
    Sep 2011
    ah i thought so... will be tig'ing up my own manifold it looks haha.
    triple Weber 45 DCOE's
    http://www.toymods.org.au/forums/sho...=1#post1362520
    ive messed around with a few things... need to get the holley manifold welded back up from correcting the angle and and the car rewired then i should be able to fire it up... any year now!!
    fucken long term projects grumble grumble
    Never late in an x8
    also this sounds like fun:
    Never late in an x8
    Sep 2011
    Quote Originally Posted by andrew_mx83 View Post
    cheers for the link. do you know if the 4M-5M-7M head's have the same intake manifold bolt pattern ?
    oh it is fun http://youtu.be/984B0CYQSTs
    That's fucken nuts!
    AFAIK exhaust ports are the same as earlier M's but intake ports are definitely different.... I imagine the bolt pattern is different too.
    Never late in an x8
    double post. bloody "smart" phones
    Never late in an x8
    Tasmania
    M,2M and early 4M are the same.Late 4M and 5ME are the same and 7M have a manifold all by itself no other M is the same.
    Cheers Brett.
    Sep 2011
    thanks for that info
