I'm not 100% sure what you're explaining, but have you rotated the engine by hand after fitting the timing belt? Just enough so the cams start to turn is fine. This tensions the belt from the crank up to both cam pulleys and ensures all slack is on the tensioner side. Then the tensioner should take up all the slack.
Then check that all your timing marks still align after rotating the crank twice by hand.
