Results 1 to 8 of 8
Thread: oxygen sensor or other gone on my mx83 cressy.. please help!
    Mar 2010
    victoria
    Default oxygen sensor or other gone on my mx83 cressy.. please help!
    hey guys.. been thru the ringer with my cressy.. 2 years after blowing head and having it fixed she's still not going great.. had the diagnostic on it but doesn't compute.. mechanic thinks the oxygen sensor may have gone after sitting around for a while and gathering moisture... or possibly the other sensor downstream.. anyone got any theories or even a spare sensor?... cheers
    May 2010
    Moscow
    Default Re: oxygen sensor or other gone on my mx83 cressy.. please help!
    didn't quite get if you had any luck obtaining diagnostic parameters
    Aug 2009
    start with telling us what its doing.. how does it run, idle, when does it play up etc.. then we can help you eliminate troubles with your engine, alot of guys here will have extensive knowledge with troublesome 7m's
    Aren't the oxygen sensors on 7ms 2 wire? As in shouldn't really come into play for idling.
    Mar 2010
    victoria
    thanx guys.. diagnostic did not even register with cressy and 2 guys tried using latest gadget.. it runs and idles ok, just slightly rough buts gets rougher at high speed.. mechanic is pretty sure its getting wrong signal from a sensor downstream adjusting mixture when it shouldn't..
    May 2010
    Moscow
    mx83 is way too outdated to accept latest gadgets. You need a thing that reads pre-1996 cars.
    check this thread
    http://www.toymods.org.au/forums/sho...10#post1461010
    I posted link to software and DIY adapter
    Hasn't blown another hg? Lol
    Tps, air leaks, afm problems?.
    I'd probably swap the afm first. Then maybe check timing or distributor.
    Aug 2009
    you can try the 02 sensor.. have you tried cleaning the fuel injectors?.. can garentee on this old girls that they have never been cleaned since factory unless there were done during the head gasket change, makes a big difference if there abit dirty.. and cars can idle fine just act jerky when your on the move as a dodgy spray pattern is really noticable under load..
  1. 1g-gte Oxygen sensor
    By Z2TT in forum Tech and Conversions
    Last Post: 12-07-2008, 01:00 AM
  2. Oxygen Sensor
    By Mexican 5 in forum Tech and Conversions
    Last Post: 22-02-2007, 08:29 PM
  3. Oxygen sensor..need a fix.
    By 88FOUR in forum Tech and Conversions
    Last Post: 20-10-2006, 06:29 PM
  4. Oxygen Sensor
    By XiL3D in forum Tech and Conversions
    Last Post: 20-10-2006, 04:57 PM
