Results 16 to 17 of 17
Thread: How to tell if ECU is in limp-mode?
    Default Re: How to tell if ECU is in limp-mode?
    Andrew,
    If the paperclip is wiggling there's a good chance you're not in the pin itself but in the plastic recess next to the pin. The pin space is about 80% of the size of the plastic recess, so it's easy to miss the pin itself.
    A paperclip in one of those pins should feel reasonably firm. I'd suggest keep poking around until it feels firmer but I guess it's hard to judge... try it and see how you go.
    You could always clean the grease out
    BTW, it's probably not most accurate to call it limp mode - a better term would be diagnostic mode.
    Mos.
    Thanks for that Mos. Clean the grease out?? Haha.
    Ok then, diagnostic mode. The paperclip (a large type) is what I started using, followed by a hair-clip of some sort. Both are metallic and should be able to bridge terminals no probs. I've had the paper clip stuck in the terminal recesses in a number of different ways, all of which felt 'firm' (ie. no wobble), but still no blinking ECU light.
    *continues to scratch head*........
    TRIKKE | Video
  1. Replacing 7mgte ecu
    Last Post: 17-04-2006, 09:43 PM
  2. TVIS not engaging due to ECU?
    By phrostbyte in forum Tech and Conversions
    Last Post: 03-03-2006, 11:39 AM
  3. Can the ECU get a fault wrong?
    Last Post: 28-02-2006, 12:28 AM
  4. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 10:31 AM
  5. Best 4age ecu???
    By cerby in forum Tech and Conversions
    Last Post: 20-01-2006, 03:46 PM
