removing the stock turbo's sucks, be prepared to cut some rubber lines that are hard as a rock.
Is the turbo water and oil cooled? if so you need water lines. if not you need blanking plugs to blank off the old water lines.
you need a bung to block the oil feed line you arent using. You need a filter or something to put on the intake air sensor. you will need some sort of catch can setup as well, or at least a setup to keep the stock system working.
do you have a new exhaust gasket?
other than that it is pretty straight forward.
				 2jz-gte - converting to single turbs - anything i should know before starting work?
