Results 1 to 2 of 2
Thread: 5SFE Valve Shim Diameter
    Default 5SFE Valve Shim Diameter
    Hello,
    Does anyone know the valve shim diameter used in 5SFE in ST204 Celica's?
    I've searched long and hard but haven't found a clear answer. I believe it's either 25mm or 28mm... but don't know which one.
    I got my GA317 from Snap On today to do the valve stem seals and am wondering if I need to turn it down a little on a lathe to fit inside the bucket bore without scoring it. If it's 28mm bore diameter I should be OK, but 25mm would see me needing to shave 1 - 2mm off the diameter to be on the safe side.
    Thanks to anyone that can help!
    I am the sun
    Default Re: 5SFE Valve Shim Diameter
    Pulled car apart today;
    Shims: 28mm diameter
    Buckets: 31mm diameter
    The GA317 tool earned it's keep with no modding needed, I got all the valve stem seals replaced... the the intake ones are really a shit of a thing to do in-situ. Now to put the rest of the car back together tomorrow and hope it doesn't blow plumes of smoke.
    I am the sun
  1. 5sfe Idle Control Valve
    By ra_28 in forum Tech and Conversions
    Last Post: 17-09-2009, 12:05 PM
  2. valve shim adustment tool
    By TooF in forum Tech and Conversions
    Last Post: 18-02-2009, 09:19 AM
  3. Need 34mm diameter Shim under cam buckets
    By MS-75 in forum Tech and Conversions
    Last Post: 15-09-2007, 04:05 PM
  4. Bucket Shim vs Valve Sprung
    Last Post: 04-09-2007, 09:35 AM
