Results 1 to 7 of 7
Thread: 4agze cam drive pulley removal
    May 2012
    Default 4agze cam drive pulley removal
    I'm trying to change the cam belt in my ae92 levin gtz. I have everything off down to the cam drive pulley and can't get it off, nor can I get the key out
    Any tips? It's currently soaking in wd40, and hasn't budged with any combination on vice grips, screwdrivers, and even a small amount of heat. I wouldn't normally nother, but I need to replace the front main seal.
    Ben
    P.S. This is the cars first new cam belt. 150,000 km... But the broken belt is why I picked it up so cheap
    Oct 2008
    TAS
    Default Re: 4agze cam drive pulley removal
    does it have 2 threads tapped in the pulley? might have to use a puller
    1983 Toyota Celica Supra
    May 2012
    I wish I was so lucky... But 23 years has locked it in pretty damn well
    Oct 2008
    TAS
    Chiba
    Before you put the new one on, smear the crank and inside of the new pulley with a bit of nickel based anti-seize, It'll never stick again.
    May 2012
    I'm almost ready to throw in the towel and pray that my front main doesn't leak. Borrowing a small 3 prong puller tonight. It appears that the factory left indents 120° apart for this purpose.
    Can the pulley be pulled over the key, or does the key absolutely have to come out first?
    Chiba
    The pulley slides over the key.
  1. 1mz-fe cam pulley bolt removal
    By Serial in forum Tech and Conversions
    Last Post: 02-11-2011, 10:23 PM
  2. front drive shaft removal - st165
    By carsanactra in forum Tech and Conversions
    Last Post: 24-11-2007, 09:39 AM
  3. 2jz crank pulley bolt removal
    By Draven in forum Tech and Conversions
    Last Post: 02-07-2006, 04:01 PM
