also misubishi pajero/triton master also bolts up. i think its very similar to the cruiser one.
i've one in mine and no issues at all - although had to make up lines to suit
PM me if you want pic.
Landcruiser reservoir is the go!!! I fitted it this morning and it looks factory, bolts straight up and doesnt leak!! +rep for ChuckLandwehr for inspiring me with this brilliant idea!! And what the hey, +rep for whoever helped out(sorry oman, you miss out because i have to "spread more love"
thanks anyway)
Toyota Car Club (Qld)
Would you mind posting a pic of the completed setup? Or pm me a pic. I'm interested in perhaps doing the same.Thanks in advance.
yeah here ya go
EDIT : The pics will work when my stupid hosting decides to start working again. Sorry
Pics of landcruiser reservior on TA22 master cylinder:
oooh. almost forgot. credit where credit is due. fook (who i guess is on here still) told me about this master cylinder being a bolt on job. that it is and it does a bloody good job - the ta22 with the ln130 surf calipers stops on a bloody dime.
My RA25 has two reservoirs coming from the Master Cylinder: https://i.imgur.com/p0eEuu0.jpg
The Tercel MC has a single reservoir: https://i.imgur.com/itg6JFs.jpg
Is the single reservoir fine instead of the stock 2?
Which MC did you use that was perfectly bolt on? Also did you have to do any other modification to put in the LN130 calipers? How about rotors, could you use the stock TA22 rotors?
What is involved with putting the R32 MC on the celica? Does it work as a 100% bolt in replacement? Also what happens if you use a ABS master cylinder? I've found 2 R32 MC's for sale, but it doesn't specify if they are ABS or not.
EDIT: for anyone wondering, here's an update since I finished the job. I couldn't easily get a Tercel MC, so I found a used MC from a EP91 Toyota Starlet (1996–1999). It shares the same MC as the Tercel (as does the Toyota Paseo, and the Toyota Cynos), and it fits perfectly in the Celica. It also has a much firmer pedal than stock, and is great. For anyone wondering, it is a non-ABS MC with just 2 port holes for brake lines.
The problem is that the bolts from the stock brake line didn't easily go into the Starlet's MC. The size and thread is the same, but the stock Celica bolts have this weird extra little flare on the end which won't go into the Starlet MC without a huge amount of force shoving it in there. I managed to get one brake line in that way, and the other just wouldn't go, so I got a pipe cutter and a flaring tool and cut the Celica bolt off the line, put one that came with the Starlet on it, and then re-flared the brake line following instructions from this video: https://www.youtube.com/watch?v=wBXRXsc--jA
Got a brake master cylinder, from a 98 mitsubishi mirage, seems to fit fine no leak.
Ill link some photos next, id like to mount the res off the top to the firewall what is the best way to go.
