Results 1 to 8 of 8
Thread: 4agze running rich?
    New South Wales
    Default 4agze running rich?
    hey i have a ae86 with a mr2 or ae92 4agze.
    i want to engineer it but i need to get around this running rich issue
    before it used to hunt a lot at idle all the time but i fixed that due to a broken vacume hose
    now it just does it during warm up. and idles fine after.
    but the spark plugs look like they are burning rich.
    like the pick i have below (if it works)
    and i have another 2 4agzes and had a look at their plugs and they are the same.
    is there anyone who has spark plugs look like these on their 4agze (below if it works)
    Chiba
    Default Re: 4agze running rich?
    What modifications do you have on the engine?
    Have you checked your oxygen sensor?
    New South Wales
    its all standard.
    nah i havnt
    tomorrow im gonna hook up the diagnoses plug/light and see anything comes up.
    how do you check the o2 sensor? put a low voltage meter on it while he car is running?
    Chiba
    Here's the test procedures:
    http://www.mr2.com/TEXT/O2_Sensor.html
    New South Wales
    thanks ill see how i go tomorrow
    New South Wales
    i hooked up a engine light it flashed twice then nothing after that..
    even so tried to get it to do it again but there is nothing..
    ill see if i over looked something tomorrow
    and try check the o2 sensor
    Chiba
    Two flashes then nothing? It should repeat the code over and over until you remove the jumper wire in the diagnostic port.
    Tallahassee, FL USofA
    Plug too cold?
    'engineer'?
    Guessing that it's been sitting/idling a lot & cold started & run intermittently & not fresh off a WOT dyno run, the plug looks normal for any engine that hasn't been under a load, BUT all those aluminum like specs look like some examples of detonation or pre-ignition.
  1. 1jz running rich on boost
    By pandaah in forum Tech and Conversions
    Last Post: 04-01-2010, 03:28 PM
  2. 4AGZE running way to rich
    By punkture in forum Tech and Conversions
    Last Post: 28-08-2009, 02:40 PM
  3. 5M Running Rich
    By Glenno52 in forum Tech and Conversions
    Last Post: 25-05-2009, 12:26 PM
  4. Running rich?
    By joey in forum Tech and Conversions
    Last Post: 26-02-2007, 07:42 PM
  5. 4agze running very rich / fouling plugs
    By Necros in forum Tech and Conversions
    Last Post: 03-02-2007, 04:19 PM
