a slight drop in RPM is normal when the alternator is charging. it takes a bit of load to charge the system and get those fans spinning up. late model commodores drop in RPM a fair bit when the alternator is put under load.
you should see what the condition of your battery is, if it needs charging a lot, there may be a problem.
use a multimeter to check teh charge rate, if its round 14.0 - 14.5v then its all good.
anymore and its overcharging, which isnt good. and results in needing to change the alternator
even have the current shunts and scope,etc
