Results 1 to 2 of 2
Thread: 4AGE oil pump circlip size?
    Chiba
    Default 4AGE oil pump circlip size?
    Ok, so I've gone and lost the circlip for the bypass relief valve in the oil pump for my 4AGE.
    Can someone please measure the size of theirs for me if they have it apart? I tried a few metric sizes at work but none fit.
    Chiba
    Default Re: 4AGE oil pump circlip size?
    Ok, turns out it was a size inbetween the sizes in out circlip set at work.
    For the record, it's a 15mm circlip, and you need 14mm washers to shim the relief valve if you so desire.
    Some good info here on how much to shim the pump.
    www.superhachi.com/theory/oilpump/
  1. gear box circlip help
    Last Post: 27-09-2009, 03:03 PM
  2. 4AGE T50 Flywheel size
    By ta22max in forum Tech and Conversions
    Last Post: 16-07-2009, 06:11 PM
  3. Fuel pump & surge tank Size
    By rogue-vl in forum Tech and Conversions
    Last Post: 22-02-2008, 06:27 PM
  4. 4age cam size...
    By dray in forum Tech and Conversions
    Last Post: 21-02-2006, 02:11 PM
