Results 1 to 7 of 7
Thread: 20 Valve silvertop wiring o2 sensor
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default 20 Valve silvertop wiring o2 sensor
    Ok ive searched everywhere but cannot find clear and exact instructions on how to hook up an oxy sensor to a Silvertop ecu.
    I have a universal 4 wire sensor with 2 wires for the heating element a ground wire and a sensor output wire.
    And there are 3 o2 sensor related pins on the ecu
    N8 - HT - Heated oxygen sensor
    M6 - OX - Oxygen sensor
    M13 -OXL1 - Oxygen sensor
    So i'm assuming I should wire one side of the heater element to and ignition switched +12VDC
    and is the other side wired to N8 and pulled to ground by the ECU to activate the element?
    and should the ground wire of the o2 be wired to a chassis earth or N9 on the ECU (sensor ground)?
    and as for the sensor output, M6 or M13?
    Or do I have it completely wrong?
    Default Re: 20 Valve silvertop wiring o2 sensor
    Anyone??????
    Nov 2011
    ht is o2 heater ground
    other heater wire goes to 12v from efi relay will be black/red on std 20v harness
    ox is o2 sensor signal normally black on std 20v loom
    and o2 sensor ground is last wire which is normally brown but i thought
    it normally goes to sensor ground as im not sure on that oxl1 wire
    Administrator Backyard Mechanic
    Jul 2009
    Doesn't the o2 sensor get earthed through the flange?
    Nov 2011
    nope
    earth thru loom
    Quote Originally Posted by dumbass View Post
    This is correct. Also here is a diagram for reference http://sites.google.com/site/chinozie/20v_wiring_a.gif
    Sep 2010
    Hamilton
    Did you sort your O2 sensor out and confirm its operation with a wideband?
    GZS55, SA23, AE30, AE70, SE70
  1. 20 Valve Silvertop Thermostat availability?
    By dank in forum Tech and Conversions
    Last Post: 17-03-2009, 01:39 PM
  2. 20 Valve silvertop intake and exhuast Qs
    Last Post: 18-05-2008, 06:53 PM
  3. silvertop 20v valve clearance
    By 4agte in forum Tech and Conversions
    Last Post: 03-04-2007, 07:44 PM
