The radiator one is the temp sensor for the hydrofan. The other temps sensors (gauge and ECU water temp) are located in the alloy neck that leads to the top radiator hose, which i believe are the ones you are showing in the top photo. Single pin is the gauge and the other will be the ECU one (which isnt stock as that normally has a green plug).
You can remove the wire/plug if you dont have the hydro water pump. I am doing it on mine, and will be taking out the whole thing (Hydro ECU and all wiring) as well.
the main one. and what are the other two plugs for you can see in the picture? (should add the main plug is not shown but joins to the item with the blue sticker on it)
been told the x7 is quicker lock to lock then x8 so while im rebuilding thought i would look into it,.
