Results 1 to 13 of 13
Thread: RA23 wheel offset
    Default RA23 wheel offset
    Hi all,
    I am looking at a set of 15 x 7 wheels with a +20 offset. Seems about right, what would be the consensus on that offset?
    Thanks
    Kev
    Yes the old Celica's are great cars thanks..
    76 RA23 18RG
    85 GSXR 750 05 GSXR 750 77 RD400
    Default Re: RA23 wheel offset
    I have searched through other threads and as I say +20 seems about right-ish but would like a second opinion.
    Kev
    76 RA23 18RG
    Kev
    I run 15x7 wheels with a zero offset, 205/50/15 tyres on my RA23.
    The fronts are right on the edge of legality as far as hanging out of the guard. Rears sit nicely inside, with some rubbing some where up in the arch when the car has me, my partner and some holiday luggage on board.
    I would say a +20 would be a good fit on the front, giving a little bit of clearance, but might tuck the wheels in too far on the rear. But you won't have outside clearance issues on either end, and I am guessing you should still have clearance on the inside edge too.
    Now - RA23-WRX
    Junior Member Grease Monkey ta22fan's Avatar
    May 2008
    May want to check your clearance on the fronts. +10 on a 7" rim is about the max you can go on a TA22 without catching on something important. I had a set of +17 7" rims on a '73 Celica, and the fronts needed a 7ml spacer to fit. Fit on the rears was spot on. RA23 may be a bit more forgiving - I'm not sure.
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    I'm running 16x7 +24 on my RA23 with KE70 R&P and MX13 Diff - this setup widens front and rear track by about 40mm each end.
    So with my suspension, +24 just fits in under my rolled guards front and rear with enough clearance not to scrape or rub. This is with 205/50 tyres.
    Before conversion with the old track widths, there was plenty of clearance all round.
    So you should be right with those ones, however as always test if you can.
    And make sure you physically measure the offset if you can before purchase, especially if its not stamped. I've had a few cases when the seller has reported an incorrect offset.
    1976 RA23 Celica - 3SGE Blacktop Beams Powered!
    1994 KZN130 Surf - Daily 3ltr Turbo Diesel Goodness!
    Ive spoken to the seller and he reckons a + 25 will do the trick
    Oct 2011
    I would be measuring it up befor you get them.
    I'm running 17x7 offset of 24mm on the front of a RA23 BUT my brake set up pushed the track out 5mm each side, allowing me to go that offset.
    They are running very very close to the strut, and I can only get 205s on the rims because of the clearance
    Feb 2012
    south australia
    a friend of mine down here runs the 15x7 performance challengers the offset is stamped as 8P and they sit nicely with 205/50s on the celica (ta22). Doesnt get looked at by the boys in blue and also looks trick - so I guess in a 7 inch wheel between 0 and +15 is ideal - More + offset or wheel width would start to get close to the strut
    Sep 2017
    What sort of offset would be required to have 15x8s in the rear?
    Sydney N.S.W
    Ive got Simmons B45's with 15x8's on the front 225x50x15s +20 offset and 15x9 on rear 245x50x15 + 25. but mine is ra28, which can take wider rear wheels.
    Sep 2017
    Quote Originally Posted by Omegaman View Post
    you think RA23 can Handle 15x8 245/60R15 rear and 15x7 225/60R15?
    the rims im looking at have the option of:
    R15x7 +10 or +20 or +25 (4x114.3 PCD)
    R15x8 +4 or +25 (4x114.3 PCD)
    Is this going to work?
    Jan 2011
    I'm not aware of anyone who has managed 245's on a 23, without body modifications.
    It's down to what tires you can get. 15's are getting harder to buy, I went from 14's for the same reason but I don't want any bigger than 15 as it just doesn't look right.
    76 RA23 18RG
  1. Wheel Offset question - will this fit?
    By Kedderz in forum Tech and Conversions
    Last Post: 13-07-2009, 04:12 PM
  2. wheel offset
    By airfireman1 in forum Tech and Conversions
    Last Post: 10-08-2007, 01:43 PM
  3. Wheel offset calculation
    By rob-ae86 in forum Tech and Conversions
    Last Post: 03-03-2007, 11:01 AM
