Results 1 to 4 of 4
Thread: 1UZFE Alternator Interchangeability
    Default 1UZFE Alternator Interchangeability
    Hello
    My apologies if this seems like a really obvious question.
    The alternator has failed in my Crown (UZS131), and I am trying to verify that the Crown alternator isn't special.
    I mainly need the following confirmation: are all alternators between 1UZFE compatable as far as mounting is concerned?
    Source of confusion: Toyota EPC
    UZS131 Crown Alternator: ToyoDIY.com
    UCF10 Celsior Alternator: ToyoDIY.com
    The bolting holes are spaced correctly but UCF10 has smaller width top mount (does that make any sense?)
    I am aware that the Crown alternator has some differences in pulley size, physical size and capacity (Cruzida, madmont). Early and late model alternators change plug shape. The Lextreme website does a comparison of the different models of 1UZ alternators. The earlier model looks identical to the later model, and both seem to look like the Crown alternator as pictured in the EPC.
    To summarise, it would seem they are all interchangeable. Is that true?
    Again my apologies if this seems like a dumb question.
    Thank you for your time,
    Brendon
    Default Re: 1UZFE Alternator Interchangeability
    They are all interchangeable.
    Nov 2011
    if the 3 pin plug is different just goto yr local auto electrician and he can supply a plug in adapter
    no need to cut and solder
    Thank you both
    So far whenever I've needed to replace something, it's had to come from Japan, so this is good news
    Brendon
  1. 5mge-1uzfe alternator wiring
    By slipway NZ in forum Tech and Conversions
    Last Post: 24-10-2007, 01:45 PM
  2. AFM interchangeability
    By mullett in forum Tech and Conversions
    Last Post: 15-02-2006, 01:28 AM
