Results 1 to 8 of 8
Thread: Does this look like acceptable shaft play-CT26?
    Low rep Backyard Mechanic
    Oct 2011
    Default Does this look like acceptable shaft play-CT26?
    Just wanted to know if this looked like acceptable shaft play. Doesn't go in and out at all ,only left to right. I'm not applying to much pressure. Stock ct26 turbo
    video-2012-02-12-14-33-59.mp4 video by aloshandookie - Photobucket
    Default Re: Does this look like acceptable shaft play-CT26?
    definately unacceptable play. You can also see where the fins have touched the compressor housing, polishing the metal. Replace ASAP.
    RA23 - Twincharged
    JZZ20 - Daily
    Oct 2011
    Quote Originally Posted by Kedderz View Post
    will do , thanks for the fast response.
    Oct 2008
    TAS
    My ct26 has similar shaft play, not quite as much.
    maybe when the oil warms up and thins out a bit its able to get past the seal in the turbo.
    1983 Toyota Celica Supra
    Certainly looks to be closer to the end of its life than the beginning You must have better eyes that me though kedz, I can't really see in the vid that it has clearly contacted the housing? A high res close up photo would show it though if that is the case.
    Remember that with the engine running, oil pressure fills the void between the turbo shaft & bush journal (hence "wet floating" bearing), so it doesn't necessarily move as far as you can inflict when stationery. That said it still looks pretty borked.....
    Oct 2011
    certainly hasn't chewed itself out in a terminal fashion. Generally you'll know when it makes contact, because boost will be accompanied by a nasty high pitched shriek as aluminium makes love to itself at high shaft speed
    Have you cleaned the inlet of that turbo, or is that exactly as it was when you removed the intake pipe? From how it looks you certainly don't appear to be ingesting enough oil from excessive blowby, which if your breather setup is correct, should be carrying oil vapour from your cam covers, through the breather to the pipe between the turbo inlet and AFM, in which case that inlet & compressor wheel should be visibly oily..........
    That's not to say though that your engine isn't burning oil from drawing oil up past the rings under vacuum, just odd that if its got that bad a ring seal, it should also be pushing quite a bit of blowby bia the breather as well.
    Oct 2011
    this is exactly how it was when i removed the intake pipe.
  1. Screechy turbo after 5SPI? No shaft play by hand.
    By TERRA Operative in forum Tech and Conversions
    Last Post: 24-01-2012, 02:19 PM
  2. Sudden turbo shaft play
    Last Post: 22-01-2008, 11:58 PM
  3. How much shaft play is to much??
    By Just1n_mc in forum Tech and Conversions
    Last Post: 08-02-2007, 12:45 PM
  4. CT12a Information (shaft play)
    Last Post: 17-10-2005, 06:53 AM
