Just pulled the gearbox out of the van this means that i can't use it for colecting any more parts.![]()
On the plus side i have compared the bellhousings (see pics) 3y at the top this means that the starter motor will sit on the side away from the exhaustas it didn't fit under the standard exhaust, (does anyone know if the 3sge/gte exhaust manifold has the same spacing and stud arraingement?)The 3y bolts up exept for one hole (see pic).so some filing and maybe a bit of tig needed
I have desided to make a flywheel from scratch useing the 2c for dimensions,the billet of aluminium is on order so that will hopefully sort out my probs![]()
Then put another groove in for the retaining clip, all done in the garage with an angle grinder and a vice. I had to turn up a sleeve to take the fwd drive up to 25.0mm to fit the rwd box. So now I should have a working electronic speedo drive for the rwd as it uses the shaft from the rwd box i'm hoping it will read the correct speed
