Results 16 to 24 of 24
Thread: how much does an 18RG weigh?
    Toyota for life REP! Backyard Mechanic TTV8RA23's Avatar
    Jun 2006
    Whakatane
    Default Re: how much does an 18RG weigh?
    Crazy that its that heavy when the 1GZFE that is now in my celica is only 202kg that was minus starter alt and PS pump though. And thats 2.5 times the capacity and three time as as many cylinders. So along with the lighter than Cast iron W50, TKO box its not gonna be a huge amount heavier than the standard setup!!
    Kiwi back yard mechanic/fabricator/machinist/welder
    http://www.toymods.net/forums/showth...t=tt1uzfe+RA23]
    Guy here at work weighed his 3SG engine and said it topped just over 200kg!!! Is this true?
    seeyuzz
    river
    GTE perhaps? I could see that with turbo and WTA, 3Ss aren't the lightest motor either.
    Sep 2011
    Just to add some 18rg weights:
    Block - 45kg
    Head - 17.5kg
    crank - 17.5kg
    18RG RA28
    Nice work Sheeps.... as usual...
    So what did the 1jz weigh as well?
    Stew
    I know I posted this a while ago but a 20V engine without any brackets, manifolds, water pump, flywheel and dry is 88kg
    Resident Mitsu-whore Backyard Mechanic
    Oct 2008
    That's bloody heavy, I honestly have to say I'm surprised at that. This has zero relevance, and is for comparison's sake only, but a dry G54BT with manifolds, turbo, alternator, starter, flywheel and clutch weighs 154kg.
    Would have expected a performance-oriented motor intended for a lightweight sports coupe to be lighter than a turbo truck motor from a lard-arse widebody Starion, lol
    -Josh
    A165H- In the works.
    practicing idiot Automotive Encyclopaedia sheepers's Avatar
    May 2006
    New Zealand
    Quote Originally Posted by Toy77 View Post
    Stew
    the JZ with turbos, twin dump pipes, alternator, flywheel (no P/S pump or air con) was 225KG's.
    sheepers.
    Last time I weighed an 18rg it was less than the 18R-C we replaced.
    It was about 135kg with oil. 18R-C was 140kg
    I don't remember if the RG had an exhaust manifold or alternator but all other bits were on it.
    It had carbies on it.
    (\__/)
    (")_(")
    The engine in my new toy weight approx 270kg. It has a little more displacement though.
    (\__/)
    (")_(")
  1. how much does a 3T-GTE weigh?
    By sheepers in forum Tech and Conversions
    Last Post: 05-10-2009, 06:10 PM
  2. Dyno and Weigh day #2 (Power vs Weight) - 22/3/09
    By ViPeR_NiPPleX in forum Victorian Events
    Last Post: 18-03-2009, 10:16 AM
  3. how much does a 2JZ GE weigh??
    Last Post: 15-03-2008, 12:21 PM
  4. how much does a cressi weigh?
    By SL666 in forum Tech and Conversions
    Last Post: 12-01-2006, 10:26 AM
