Results 1 to 2 of 2
Thread: 2JZ auto Q's
    Nov 2008
    Default 2JZ auto Q's
    Howdy
    Just doing a bit of research for a conversion I am wanting to do this year. Im wanting to fit a 2JZ-GTE into my 2nd gen 4runner, Just wanting to know if it is possible to utilise the 2J's auto transmission with a transfercase by using parts or housings from a 4x4 auto?
    Id like to keep it 5spd with my current R151f but conversion kit+clutch costs as well as other dramas will blow the budget.
    Also am I under the right assumption that if I was to source a halfcut the engine+auto should all be plug n play with its associated ECU's and lumes? Other then the wiring for ignition, dash etc?
    Thanks for info
    Gen2 LN130 4Runner
    3" SAS trail-gear kits FnR, FnR ARB lockers, dual transfers, 30s longfield axle set, 33" MTZs road, 36" Iroks play, fullbarwork.........etc.
    Default Re: 2JZ auto Q's
    The Surf transfer case will fit up to your auto . You will need to cut the output shaft and make provision for the 2JZGTE speed sensors and drill and tap a hole in your casing.
    see this thread
    Toyota 4WD Surf Owners :: View topic - V8 1uzfe into 4Runner Project
    Jealousy is a curse
  1. Replies: 4
    Last Post: 09-11-2009, 12:24 PM
  2. Replies: 5
    Last Post: 29-01-2008, 07:35 AM
