Results 1 to 8 of 8
Thread: 1KD-FTV injector copper washers failing
    Oct 2008
    TAS
    Default 1KD-FTV injector copper washers failing
    hi,
    Had a 2005 hilux 1KDFTV common rail at work today complaining of smoke when he parks facing down hill.
    Pulled the cam cover and injectors to find the copper washer had failed letting combustion gases up to the O ring. The O ring had fallen appart which allowed the oil to run down through the copper washer and into the combustion chamber. but only when the car was parked on a slope.
    Also, the intercooler piping was soaked in oil. we put this down to the combustion leak increasing crank case pressure.
    Anyone heard of similar problems with 2005 hilux's?
    cheers.
    1983 Toyota Celica Supra
    Default Re: 1KD-FTV injector copper washers failing
    I think the failing copper-washer was mentioned in this thread: http://www.toymods.org.au/forums/tec...ts-pieces.html
    Oct 2008
    TAS
    Ah yes, and the service bulletin is issued to be done at 150,000. this lux has 155,000k on it lol.
    Nov 2011
    i did a deisel course recently and i would hate to own a late model hilux
    and pick up a bad batch of fuel
    if u dont catch it quickly enough it can end up costing up to 8000 bucks to get it fixed
    wa
    Quote Originally Posted by CELICASUPRA7M View Post
    There is no service bulletin for this to be done that i know of, at least not in australia.
    How tight were the injector clamps when you pulled them off?
    8k to fix doesnt sound right for a bad batch of fuel.
    Fuel filter-40 dollars
    injectors- 4 x 750ish
    Fuel pump-1500
    maybe it was a dealer-sponsored course, e.g. if check engine light illuminates, advise owner motor is ruined due to out-of-warranty use and quote cost of pallet motor ex-japan?
    Oct 2008
    TAS
    parts turned up today, they included aluminium washers.
    Injector bolts were def tight.
    flushed oil and she's running mint now.
    Feb 2007
    Timaru
    Yes the seating washers are a known problem.
    They have been known to let the combustion gases into the tappet cover and cook the oil,
    which then blocks the oil pickup in the sump.
    The other issue is the return line from the injectors leaking which is also inside the tappet cover,
    which dilutes the oil down until they run a bearing of the oil/diesil mix come out the turbo as the fill up past the drain.
    And the HP pumos wear too.
    We have had numerous issue's with them here as we do a lot of diesil EFI stuff.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  1. 1/8" copper tubing for TIP
    By waldo in forum Tech and Conversions
    Last Post: 08-11-2010, 11:14 PM
  2. Copper Gasket Material??..can you buy?
    Last Post: 08-11-2006, 09:45 AM
  3. Hub-to-CV nuts and washers....
    By nick.parker in forum Tech and Conversions
    Last Post: 22-07-2006, 11:22 AM
  4. Are 4AGE head bolts supposed to use washers?
    By WHITCHY in forum Tech and Conversions
    Last Post: 27-06-2006, 07:13 PM
