Results 1 to 15 of 15
Thread: Why do i have to rev my 1jz vvti to avoid stalling on cold start? (microtech)
    Jan 2011
    queensland
    Default Why do i have to rev my 1jz vvti to avoid stalling on cold start? (microtech)
    heyhey. i have a 1jz vvti running on a microtech lt16. starting it cold. even on a warm day i need to rev it to keep it alive. Is there a cold start plug in or what can i do?
    Nov 2011
    Default Re: Why do i have to rev my 1jz vvti to avoid stalling on cold start? (microtech)
    cant do anything hehehe
    thats factory microtech
    how does the vvti go
    really fast?
    Yup, that's microleb ECU. I imagine it doesn't have adaptive idle up control (or most likely it doesn't have the ISCV connected at all). You can do some tricky stuff with the fuel/ign maps, but it can cause issues at other points. If that's the only driveability issue you've got, you must have got a good installer/tuner!
    I'd also be surprised if they connected the vvti...
    -RM
    basically that's a poor ECU choice for that engine - I'm 99% sure microtech can't do vvti (and definitely not well), so you'll be losing out a lot on responsiveness there... if you're looking at modifying, I'd be considering a new ecu
    Nov 2009
    Haven't played with Microtech for about 6 years, but it wouldn't be my choice for this engine. The Microtech does have a cold start feature that you can play with to change the cold strart fuel which wont affect the main fuel map. As Draven said I doubt the Microtech is controlling the VVTi, as I couldn't find any reference for the LT-16 supporting variable cam timing. Definately change ECU's.
    Oct 2009
    Microlebs are good for rotors and not much else, far better options out there
    Jan 2011
    queensland
    Thanks lads. wgat would be my best option?
    Is it a big job to swap ecu???
    google aftermarket ecu vvti and have a look
    Also depends hugely on what your budget and technical expertise is as to whether it's a "big job" - but at the least you'd be paying for an ECU and a tune, which are not cheap items.
    Autronic, Haltech, Wolf, Motec and Megasquirt all do vvti in their higher end/newer models... basically everyone except microtech
    Nov 2011
    Link or vipec
    Easy to use and set up
    Which ever ecu u get yr budget will be 2 to 3 g maye more
    By time get it running properly
    Adaptronic will be ideal for this. Dual channel VVTi control, adaptive idle, adaptive fuel and ignition...and given that you're in the East, excellent support as well. I can't speak highly enough of them, and the base model 'select' ECU will do everything you need. Just find a workshop that you trust to fit it and tune it!
    -RM
    Nov 2011
    I just can't handle adaptronic software
    It's not user friendly or easy to understand
    Jan 2011
    queensland
    Far out. my tuner has done a.fair few 1j with microtechs. wiah he.mentioned it earlier. its goes well. but feels like somethings missing. like it doesnt go like a newish engine with vvti.
    I make 230 hp with 13psi with intercooler 3" all the way zaust boost controler.
    Quote Originally Posted by bosslock View Post
    with similar mods I made ~300rwhp... the microtech was a good (read: cheap) ecu for a non-vvti 1jz in an older car, because there was nothing complicated to do (cold start could still be a little annoying during the coldest days in winter).
    It's just not the right ecu for newer cars/engines
    Junior Member Backyard Mechanic Rhyno's Avatar
    Jan 2010
    NT
    Just wanted to add my 2 cents,
    My daily ride has a Gen 1 3sge running an lt10-s, x4 box and four bosch ignition coils. I live in Darwin which even in the cool part of the year is fairly hot, and every morning I go to start my car sometimes it will turn over and get away on the first turn off the key, other days it will try and run, splutter a bit and die. After the 2nd to 3rd attempt it gets away no worry, don't ever need to use accelerator to keep it alive.
    On another note, I always let my engine heat up to 60 degrees, before I eve put it in first/reverse - even at very low throttle, like less than 10% the car feels slugish. As soon as she is warm at 82 the car drives like a dream.
    Haltech is the shiznit
    The vipec & current Link ECU's are awesome with toyota reluctor and vvti setups, they'll control the 1jz's ISCV perfectly too.. Adaptronic's also work well but I'm also not a fan of their interface/datalogging.
    I'd agree that you're about 60-70hp down on where the power should be. If you are going to change ECU's, I'd be hoping whoever installed the microtech didn't mess with the factory triggers/teeth to get it running.
  1. 22RE - common problem ? Hard start? Cold start injector?
    By Toyocorona in forum Tech and Conversions
    Last Post: 20-01-2010, 07:41 PM
  2. Cold Start Switch - Where to buy?
    By 88AW11SC in forum Tech and Conversions
    Last Post: 07-09-2008, 01:48 PM
  3. 3s-fe cold start problem
    By neon in forum Tech and Conversions
    Last Post: 15-11-2007, 10:53 AM
  4. Over revving on start up and stalling for no reason on a 6MGE
    By Johnzoku in forum Tech and Conversions
    Last Post: 18-02-2007, 07:43 PM
