Results 16 to 21 of 21
Thread: Bypass 2JZ-GTE VVTI speed sensor?
    May 2010
    Moscow
    Default Re: Bypass 2JZ-GTE VVTI speed sensor?
    dumbass running sta/nsw pins right is exactly fooling ecu, unless it has separate park/neutral pins
    Nov 2011
    it's not really fooling the ecu
    it's actually wiring it up like factory
    so I don't class it as fooling
    older ecus have one pin missing on
    manual ecus compared to auto ecus
    so just like wiring a manual ecu with no
    so basically no nsw pin
    there is nothing else u need to do
    Jan 2009
    Christchurch
    I was more concerned about functions the ecu does with the speed signal that could effect performance.
    Nov 2011
    doubt it will effect much
    the ecus arent as smart as compared to what we have these days
    might affect mixtures slightly at cruising speeds but u prob wont even
    notice if its running properly
    Jan 2009
    Christchurch
    Could this be bad with a boost increase? Plan to have all the basic power upgrades and run 15/16 psi of boost but only when i have it running nice with the factory boost setting of course. Was planning to have a air/fuel gauge installed anyway. Have finally got my engine mounts, Would you believe $218 brand new from Toyota imported from japan! Just have to paint engine bay, trace 12 more wires and plumb it up and can finally have this thing running
    May 2010
    Moscow
    Yes you will note major change in performance. It will go past 180 now :-)
  1. R154 1jz abs sensor to Soarer speed sensor 2?
    By 1jz_manual_project in forum Tech and Conversions
    Last Post: 10-08-2011, 12:21 AM
  2. 1JZ vvti speed sensor on auto
    By Wizzard in forum Tech and Conversions
    Last Post: 25-08-2010, 07:58 PM
  3. Speed Sensitive steering and R154 speed sensor questions
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 23-10-2007, 08:18 PM
