The Hilux/Pug conversion uses a Corona XT130/RT132 strut (not crown) which has an integral caliper mount. They can be found, prob is wreckers have woken up and charge a few bob. There are not too many other options without some clever machining. Ma61 vented rotors and calipers with a machined up caliper mount is do-able, but then you could go small Wilwood 4spots with this makes a nice upgrade.
The rear diff in a RA40 is the 6.7" T series diff. Options include finding a GT F series diff from an RA45 (yes they do exist) and it bolts straight up. There is the F series diff from a Mk11 Corona MX13, these can be fitted with some welding of new brackets. I think the Tarago/Townace YR21 F series diff fits.The ultimate is the Hilux 8" diff which also needs welding and you can change the 5 stud axle to 4 stud or use 5 stud rims (same pattern as Ford or Crown).
Then with some mucking around, you could go big falcon front brakes, hilux rear diff with falcon rear discs and the choice of rims is endless.
