Results 1 to 7 of 7
Thread: 2JZ-GE Auto - Limp mode - No error codes :(
    Default 2JZ-GE Auto - Limp mode - No error codes :(
    On the off chance any of my fellow Toymodders have hit this issue I thought I'd post it up
    As some of you know my Crown wagon is 2JZ-GE powered with the factory Auto and ECU. The package is from a JZZ31 Soarer (07/1994 model) and has run faultlessly for 6 years but has developed an intermittent issue. It is going into full limp mode, BUT is not giving me any error codes. Even if I put it into diagnostic mode, get it to misbehave and check I get nothing
    Anyone else had this issue and been able to track it down ?
    At present it looks like it will be off to Toyota for a plug into the Toyota Handheld scanner to see if it can tell me whats wrong.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Nov 2011
    Default Re: 2JZ-GE Auto - Limp mode - No error codes :(
    full limp mode can be a miillion things
    u havnt even said what symptons is doing hehhee
    its prob the auto starting to fail
    if the symptoms cut in and out irregularly then its prob electircal but should bring up codes
    if they slowly come in and out its prob mechanical
    look at oil condition
    doubt u will read much by fitting scanner onto it
    especially the auto side of it
    [removed]
    .. thought you were talking about engine ECU, not the auto ECU.
    Just to clarify, the auto transmission is fine.
    Engine is going into limp mode. The 2J only has one ecu that rules them all (Engine and gearbox)
    As for symptoms, full limp mode is the symptom. But for those that don't know, full limp locks the auto into 3rd gear and dumps in fuel.
    Rod, I had that happen in one of my previous Celsiors. Changed the 02 sensors on advice from my lad, and all returned to normal.
    cheers Chuck.
    MS51Crown Coupe,
    no turbo and auto... that is why it is limp
    does it to me every time....
    I have nothing constrctive to add mate... but have been at work for over 11hrs and am bored now....
    Stew
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Does the 'check engine' light come on when it goes into limp mode?
    Out of curiosity, do you have a lamp connected to the O/D light output of the ECU? Even though the one ECU controls both, the engine and transmission parts have their own diagnostic lamps (transmission part of the ECU uses the O/D OFF lamp).
    Strange that it doesn't report any faults... :S
  1. jzx90 mx83 running in limp mode.
    By chaserbuddy in forum Tech and Conversions
    Last Post: 22-09-2011, 03:41 PM
  2. A340 problem - limp mode
    By BLACKCAT in forum Tech and Conversions
    Last Post: 04-05-2009, 01:31 AM
  3. 4agze stuck in limp mode
    By Intense in forum Tech and Conversions
    Last Post: 10-09-2008, 08:37 PM
  4. ST185 Major Limp Mode Probs
    By Bourkey in forum Tech and Conversions
    Last Post: 11-08-2008, 08:45 AM
  5. How to tell if ECU is in limp-mode?
    By Andrew162 in forum Tech and Conversions
    Last Post: 28-05-2006, 01:12 PM
