Maybe add some plastic case (like the one usually wrapped around stock toyota harness) and ensure the cable will not break at connection points due to vibration. Maybe add heatshrink or something at terminals to smooth transition from hard metal terminal to flexible cable. Then it's ok to use it.
p/s to give you some rule of thumb, if you can measure as much as 1V at cable ends under full load then consider it thin for your application.
