Just stopped working all of a sudden? Had been woring perfectly up until that point? No noises, sluggish gear changes or anything else from the box before it 'died'? Have you physically checked the gearbox from under the car to make sure there's no loose plugs etc?
I'll have a stab in the dark, though not sure how helpful it will be to you. Is an idea at least, before someone more experienced chimes in. Have you checked the ECU? To get to it you need to take off the passenger lower half of the dash, which is basically just the glovebox. To memory there is 4 phillips-head screws to take out, one is behind the speaker grille (which pops off easily), two are behind the black trim on the bottom of the dash, in the footwell (which also pops off easily) and the other is at the top right corner of the glovebox when the lid is opened. With the glovebox out you can easily access the ECU which sits right next to the air vent pipe for the left side of the dash and is right up under the dashpad/top half.
I'm probably way off, but sounds like a relative suggestion to me.
