Results 1 to 10 of 10
Thread: Another 1jzgte hydro water pump removal question
    Dec 2009
    Tasmania
    Default Another 1jzgte hydro water pump removal question
    Hopefully this hasn't been covered before, couldn't find anything when searching.
    So currently my car is undergoing removal of the hydro waterpump in replacement of non hydro setup from jzz30/2jzgte. My Engine is a jzx81. All genuine Toyota parts are being used But have just realised after doing the final touches like putting on the non hydro waterpump pulley that it doesn't fit. After some research and talking with the supplier, we have realised what we put on was a waterpump from a VVTi 1jzgte. Part number being 16100-49856
    Does this matter? It all bolted up fine. Didn't haven't to use the rear case off the original pump or anything. Do I just get a pulley from a jzx100 and off I go?
    Supplier willing to get the correct one. But just wanting to save the hassle of pulling it all back off.
    Hopefully someone can help
    Mark
    P.s sorry about the lack of punctuation, using a flogged out iPhone
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    Default Re: Another 1jzgte hydro water pump removal question
    the pulleys are different on the hydro to the traditional water pumps.
    Either get one for ~$120 from Toyota, or an alloy set off ebay for ~$100.
    Dec 2009
    Tasmania
    Yeah that's fine will do. But the pump itself is ok to use
    as long as all he pipes line up, all good. there are (I think) a total of 3 difference water pump on JZ engines
    Dec 2008
    western australia
    if ya need a jzx100 pulley i can help.
    but as others say , if holes line up and bolts ok ok , and doesnt leak ! then shouldnt have any issues id assume
    Dec 2009
    Tasmania
    A jzx100 pulley would be great. Can u pm me with a price posted to Tasmania. It all bolted up fine. Apparently there was one extra pipe which my mate blocked off. (obviously not needed?, I read about that on one of the threads about this swap)
    Hey, are you converting to clutch fan or thermo?
    I've got a JZX100 water pump pulley here if you get stuck also.
    Phil
    Dec 2009
    Tasmania
    Converting to thermo's. I'll take whoever has a Pulley and can get it to me in tassie by the weekend. Pm me with ur price and we will go from there
    Dec 2009
    Tasmania
    Jzx100 pulley anyone?
    May 2006
    tas
    I used all jza80 mechanical parts in my swap. Occasionally the pulleys pop up 2nd hand. I managed to get a fan and pulley for about $50 2nd hand off of supra forums. Ended up going thermos and i couldn't fit the clutch fan. Alloy pulleys can chew out belts, I stuck with a factory steel one that i know will be reliable.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  1. 1JZGTE Water Pump removal... A question or 2...
    By ZZT231 in forum Tech and Conversions
    Last Post: 26-05-2006, 08:47 AM
