Results 1 to 12 of 12
Thread: How to prevent steel coil-overs from rusting?
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default How to prevent steel coil-overs from rusting?
    Ahoy hoy,
    I recently purchased a set of Tein Superstreets for the Supra. Because the threaded part of the body, lock nut and the spring seat are made of steel the kit originally came with an anti-corrosion spray. Because I bought the kit second hand, I didn't get this spray and have no idea what it was?
    What would be a good alternative? WD40? Fish oil? Maybe something similar to that plasticy spray you put on battery terminals?
    Any suggestions as to what I could do to prevent the threads from rusting up would be appreciated!
    Cheers!
    Default Re: How to prevent steel coil-overs from rusting?
    WD40 would wash off in 2sec.
    Inox would last longer, but probably still not long enough.
    So fish oil might be the go. Get it in a spray can, will be easier to coat everything with it.
    Vaseline would do the job as well.
    Aug 2009
    Ensis fluid, sold by Shell can be bought in 1lt and 4lt cans from most Shell servos . It's a rust preventative. I have used it on exposed parts and on body panels and doesn't wash off and it doesn't smell like fish oil.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    id say fish oil too that will last for ever
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    Jul 2009
    I covered the threads with duct tape on mine after I set the suspension up.
    The other option that might work is the motorbike chain lube/wax shit since it stops rusting and lubes up the chain rollers.
    Thanks for the suggestions fellas. I stopped by a servo to look for this Ensis stuff but couldn't find it. Think I'll grab some fish oil tomorrow, chain lube is also a good alternative now that I think about it!
    Cheers!
    Mar 2011
    i'd use the Belray motorbike chain lube. it's a white wax-like product, and doesn't pick up as much crap as the other lubes on the market (e.g. Motul chain lube).
    SHEPPO..
    You don't want anything that attracts dust, in an environment where all manner of sh1t gets thrown up by the tyres off the road.
    I've successfully used Selleys "Ezy Glide" in the green can. Its teflon based and stays dry, benefit being you can still adjust your spring mounts without having clean any crud off.
    Phil
    Lanotec Lanolin oil - as a suggestion
    Nov 2011
    Quote Originally Posted by Youngy View Post
    Was going to suggest the same thing. Used to use it on the road sweepers and also when I was doing marine work. Stopped the engine covers on the travel-lift from falling off every few months, Would also use it on Propellors to keep marine growth at bay.. Damn good stuff
    His. 2005 GRJ120 Prado VX
    You could get the parts which will rust chemically blackened. A preety inexpensive process which any heat traeatement place will be able to preform. If you are in sydney I can give you some places you could try, just PM me.
  1. 4 link setup with coil overs
    By BeRad in forum Tech and Conversions
    Last Post: 20-08-2006, 08:57 AM
  2. best coil-overs for drifring86
    By rollamattae86 in forum Tech and Conversions
    Last Post: 21-03-2006, 07:13 AM
