Results 16 to 28 of 28
Thread: SOLVED!! - 1UZ Stalls, but not when bridging FP and B+ AND 12v to B+
    Western Aus
    Default Re: 1UZ Stalls, but not when bridging FP and B+ AND 12v to B+
    From what i remember, +B is an ignition switched power feed, it should supply 12v with the ignition switched on. Do a continuity test between the ecu pin and the pins for the efi relay (the one pictured) and if its fine, could be a buggery relay, or something that supplys the relay with power is fubar.
    May 2011
    Act
    Thanks for the help so far.
    I managed to fix quite a few things.
    But now i have no power windows, Tacho, Dash lights, Fan /AC controls etc... So Im still fixing bits.
    One question, there is a screw on the ECU plug, and when I try to undo it it just keep spinning??? Is there a way to make it undo>? Like do I slot something in to lock the threaded bit or something??
    That screw is just there to keep the plug on.
    Once you've unscrewed it all the way, just pull the plug off.
    Nov 2011
    And to add to that the screw (bolt) doesn't come out of the plug. It should slide back and forth in the plug when undone but if the captive nut on the ECU side has been overtightened and come adrift then you are quoting Apollo 13 "Houston we have a problem".
    If the bolt is sliding back and forth as Cruzida has said you can slide the big one piece plug off. if not man are you in for some fun which is to carefully try to take the ECU apart and slide the plastic retainer off the front of it and grip the captive nut some how (after that cable ties are your friend to hold the plug in). Now lets hope that this worst case is not the case
    His. 2005 GRJ120 Prado VX
    Nov 2011
    tacho u need a booster and a sig converter if u want it to read right
    dash lights u prob forgot to plug dash light dimmer in
    rest of stuff check fuses
    Nov 2011
    also seems like the sparky who touched it at start has no idea
    and was using that car as a learning experience
    to get most things working properly u need to use most wires
    from the 3rd plug under the dash that plugged into the 7m ecu
    You wont need a tacho booster, but you'll need to convert it to a 6cyl signal.
    The tacho is adjustable, but you'll need to adjust it against a known source.
    May 2011
    Act
    Default Re: SOLVED!! - 1UZ Stalls, but not when bridging FP and B+ AND 12v to B+
    SOLVED! FIXXED!
    So I was given a HUGE book for the MX83, its a factory service manual, but for USDM.... But it gives a fairly good idea what goes on.
    Guess what, there is a fuse panel just to the right of the accelerator pedal, and a few of them were blown! I shit you not, three 5 cent fuses caused weeks of frigging around. Was a great learning experience though.
    ALSO
    There was another Relay, located high up on the passenger strut tower, has a rubber shell thing... well that had a lot of corrosion in it and I pulled it all apart and cleaned it up. After that, the engine started first go, no need for bridging B+ etc.
    AND
    During the cars stay in the driveway, some prick went throughout the glove box & centre console and made a huge mess, realising there wasn't anything worth flogging... bastard left the door ajar and I didn't see it for a few days, battery was uber flat....
    SO Im guessing the JDM Fog/headlight install with the relay etc may of had something to do with the fuses blowing, and also that relay with the dodgy connection....
    Now all is good, thanks so much for the replies and emails and diagrams... I am now a free man, not depending on busses and lifts to work!
    Car feels like its 500kW now (cos I haven't driven it in ages...) but really its only like 130kw lol
    That will teach me to lock up at night...
    Tallahassee, FL USofA
    Quote Originally Posted by Cresleepa View Post
    Yes it would be a real learning experience to find that blown fuses for some accessories also caused an intermittent fuel and/or ignition failure.
    You've inadvertently fixed, probably temporarily, whatever the original problem was, nothing more. Those fuses are just another problem/issue.
    Jan 2008
    queensland
    SOLVED! FIXXED!
    that was probly the problem though
    neil
    2009 aurion
    Purple 2000 Hilux - 1UZ
    May 2011
    Act
    I think the Fog Light install wasnt really the best, last night I pulled it all out and started again, now has a proper narva relay, correct terminals etc and all is good!
    Im summary:
    Rubber shelled relay had corrosion and bad connection
    Loom had dodgey connectors
    fog light install wasnt up to spec
    fuses blown (also would of explained why the A/C stopped working...)
    Also the connectors for the 2x terminal temp sensor were bodgey, have got new connectors and the fans work properly now
    Nov 2011
    Great stuff! Hope what I sent you helped
    May 2011
    Act
    Sure did help alot!
    It was great seeing it in colour, all the wiring made sence then. Toyota actually do a pretty good job in their electrical design in my opinion. (although currently Imimpressed with Boschs setup with CANBUS and all that... very tricksy!)
    So I took the beast out today, loved every minute of it.
    And yes you were right, it was a very simple little thing, and a headsmack to myself for not looking hard enough!
  1. for the electrical gurus: bridging wires from the ECU
    By wagonist in forum Tech and Conversions
    Last Post: 26-08-2011, 12:28 AM
  2. bridging nuetral start switch on cressida
    By Azzamk2 in forum Tech and Conversions
    Last Post: 25-11-2008, 03:32 PM
  3. Gen 3 1ggte stalls out when stopping? Help!
    By Gforce6 in forum Tech and Conversions
    Last Post: 11-04-2007, 07:50 AM
  4. Need help with bridging the neutral start switch
    By frk5how in forum Tech and Conversions
    Last Post: 28-11-2006, 12:45 PM
