Mate look up about 5 posting the reluts of compression test are there. As for blow by yes i know it has some. Although the engine doesn't use oil between oil changes so can't see the point at this stage to strip it done. As for the Head has been off about 2 years ago when a valve got bent. At that time i replaced the valve and did a 3 angle cut on the head for all the valves. Also replace timing chain as I notice one link was broke and just holding together. I have another head here that I purchased of Rod. Got some Cam ground just have to get them shimed. But can't see the point putting that head on until i rebuild the bottom end.
Just for a recap the Compression results were
Hot Dry results only
1 150
2 165
3 155
4 155
As saying before I know these are low but results are the same as when i first bought the enigne over 3 years ago.
Haven't Check the Dizzy shaft or the auxiliary venturi in the carbies yet I'll have to some reading do see where it is. But I'll be having a look tomorrow thank kingmick and Billzilla for some ideas.
