Results 1 to 2 of 2
Thread: LS400 Speedo problems
    Toyota Hoarding Grease Monkey squish_m8's Avatar
    Sep 2008
    Default LS400 Speedo problems
    Hi all,
    I recently purchased a '92 LS400 knowing that the speedo had issues. The guy before me said he had replaced the speedo driven gear and it worked for a few weeks. When I went to inspect this I found that an 18 tooth gear had been installed and teeth had been sheared off. I looked up the VIN and found that a 17 tooth gear should have been installed so immediately I ordered one straight from japland. I have since installed this and it worked perfectly for about 150kms, then one morning I go to take the car to work and find I have no speedo again :/
    I have also noticed since having no speedo that the odometer still functions fine.
    Today I have gone to see if I could find what the problem is and I'm now stumped. The driven gear looks fine, no teeth missing like the last one. The transducer seems to be plugged in properly. I have tried driving the gear manually with no positive results. I have also tried a different transducer from the local wreckers.
    All I can think of so far is that I have a loose connection somewhere or both transducers are dead....
    Any ideas? I'd like to get it going again asap but not sure what I should try next
    Cheers, Kieran
    Default Re: LS400 Speedo problems
    If the odometer works fine, then its just the speedo gauge/display/needle that is stuffed.
  1. celsior/ LS400 speedo issue.. URGENT
    Last Post: 12-08-2012, 08:08 AM
  2. Speedo Problems (Does its own thing)
    By Blue23 in forum Tech and Conversions
    Last Post: 17-10-2008, 08:37 PM
  3. Speedo Problems?
    By Ghostrider in forum Engine & Driveline Conversions
    Last Post: 23-01-2008, 10:40 PM
  4. Speedo problems
    By CoronaC in forum Tech and Conversions
    Last Post: 02-03-2007, 07:28 PM
