Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: 4agze Super Charger Clutch
    Default Re: 4agze Super Charger Clutch
    If it's a track car, there's a good chance that the supercharger is never disengaged, I think it's 3 or 5 seconds after you lift off before the computer disengages the clutch, and I doubt you'd get that on the track. Maybe hook a little LED or something up to the trigger for the SC clutch to see how much it's acutally off. Maybe welding it is an option...but if you're going to do that, I'd machine a smaller SC pulley up so you get bigger boost without the problems of a bigger crank pulley...
    RM.
    Quote Originally Posted by ryguy86
    but is everyone in agreeance that its cool for me to just weld up the clutch and have the sc running all the time??? will this cause me any long term issues???
    other than going through LOTS of petrol... which doesnt bother me.. its only a track car anyway...
    wa
    man i tell you what.. when i cooked the supercharger clutch.. the smell was horriffic.!
    also what kind of oil is reccommended in the SC?
    most people i know of including myself are using Mobil synth gear oil
    A common fault with the 4agze motor is the relay for the clutch that fails, have you followed the wiring and bridged out the clutch to see if it is working?
    1988 AE82 Corolla Seca - 4agze
    There is no car fast enough for me...
    nuts Grease Monkey
    auckland
    just a warning.. if the bearing fails.. its likely to do this.. cook the windings in the coil. this one which i've just pulled apart apparently stopped working because the insulation melted off the plug wire and shorted out. eek
    -Mark
    E2 + E7 fan
    electronic engineer 1st year Apprentice
    in reply to one of your questions that hasn't been addressed yet ryguy86.. doesn't the sc14 bolt straight on relacing the sc12 or is the sc14 too big???
    New Zealand
    the SC14 is bigger.
    the recommended oil is toyota sc oil
    please, no more PMs!
  1. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  2. What Clutch Slave Cyl for 4AGZE with W55 ??
    Last Post: 16-05-2006, 11:33 AM
