Ok
One of the first things that i require to know is
On the RHS going off to the RHS Kick Pannel fuse area via a Black plug is 4 wires
1/ Large White wire ( Approx 8mm) which when you follow it back it goes to the alternator and thats it. Is this still needed and if so what is is for ? . There also is one of these same size from the alternator back around the eng o the LHS eng by Fuse Box J3.
2/ Smaller large white wire ( 6mm approx which goes over to the fuse box J3 onlyon the AMI 40A fuse link
3/ 4mm black wire bit thickers that all the standard size wires which connects up and branches offf to various things.
4/ 4mm Black - Orange wire that also connects up to various things ie fuel pump relay etc.
Also what are these items as shown below and are all of them required to be connected for a 4AGTE setup using the standard comp?
Any info appreciated on this
