Results 1 to 3 of 3
Thread: 1g-gte into ae86
    Default 1g-gte into ae86
    yes i has tryed doing a search but it doesnt always find what u want even if u know its there ..
    just a couple of helpful tips would be nice like what radiator to use what sump to use etc all help will be much appricated . thanks
    Default Re: 1g-gte into ae86
    better idea - Buy Lambolica's AE86
    ... it already has the 1G-GTE, trueno front end, and looks HORN.
    Captain Insano Grease Monkey sanchez's Avatar
    Quote Originally Posted by mrf_ool
    i used a front mount sump on my conversion, even then it had to be shaped a little in order to clear the crossmember. i have a problem at the moment where the sump hangs quite low so i will eventually get around to making a custom sump.
    as for a radiator, i bought a nice large one from a friend of mine which had the inlets and outlets in the right areas. not sure exactly what it's out of but if you need, i'll take some pictures for you.
    if there's anything more you need help with, send us a few PM's and i'll try to help out as much as i can
    1GGTE powered AE86
    JZX100 Mark II
    dude he is in darwin...you could use cocaine powered monkeys to move your car and the RTA wouldnt care
  1. Replies: 8
    Last Post: 27-04-2006, 09:48 PM
  2. AE86 Axle upgrade needed...
    By irishtwincam in forum Tech and Conversions
    Last Post: 07-03-2006, 06:19 AM
