shouldn't need to remove the oil pump to get to that large bolt - looks like it is even outside the timing cover?
unless you want to check the pump out
neil
hey i couldnt find any info other than what people could tell me so while i did mine i took some pics hope it helps anyone who is building a 1g. for those who dont know this will raise the oil pressure so the bearings get some more oil as its a normal problem for the 1gs
first remove the oil pump
remove the large bolt from down the bottom be careful for the spring
add a small washer to under the spring then reassemble easy as that
RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
corolla sportivo daily LIFT
neil
2009 aurion
Purple 2000 Hilux - 1UZ![]()
Shimming the overflow valve just makes the point where that valve opens later.
Im guessing thats what you want?
ie. if its shimmed at stock say 70psi, the oil will get to 70psi then the valve will open. If you shim it then it might open at 80psi instead.
Now 9AGTE 410kw atw
It has worked for me, for a while. Oil starvation is a common problem on 1gs. Great 2ltr other than that.
88 gz20 soarer built 1ggte gt30/40 osgiken twin plate j160 gearbox.
Mine always flows 25psi to 65psi all day every day![]()
1 G L O V E88 Ga70 supra --- Under powered and over cooled Daily
