Results 1 to 15 of 17
Thread: AE85 Power! Basically done... came up ok, 2.5 years of work
    Jul 2008
    Christchurch
    Default AE85 Power! Basically done... came up ok, 2.5 years of work
    Pictures say it all... 175WHP (more to come), fairly extensive shopping cart.
    Before...
    After...
    Jul 2008
    Christchurch
    Default Re: AE85 Power! Basically done... came up ok, 2.5 years of work
    sus-023 Backyard Mechanic Slidin23's Avatar
    Apr 2007
    123 fake street s.a.
    that is pure awesome!!!!!!!
    That is very nice work, looks great
    88 gz20 soarer built 1ggte gt30/40 osgiken twin plate j160 gearbox.
    oregon
    wow... is that a silvertop? making 175whp is fantastic... would love to see the dyno print out and here about what all you did to get that.
    The intake looks very impressive
    Jul 2008
    Christchurch
    Quote Originally Posted by oldeskewltoy View Post
    Its a silvertop bock, and blacktop head. The blacktop block is not good, because of the hydraulic tensioner, I killed 2 brand new ones (and one motor) with them.
    Engine:
    Custom header (SS 304 in 1.5" diameter primaries and 660mm long, to a full 2.5" SS 304 exhaust, DEI header wrap
    Custom Aluminium intake with CNC backing plate with built in 45mm velocity stacks.
    3SGTE injectors
    Coil On Plug ignition
    Sliver top block (I grenaded a Black Top one) with balanced crank, ARP Bolts throughout, ACL bearings, Tomei rods, custom CP pistons, 15:1 CR.
    288 degree 10mm lift Kelford Cams
    Supertech 1mm OS valves, Supertech Valve Springs
    Excedy Lightweight Flywheel
    Setrab oil cooler and TRD oil filter with HKS adapter off the block
    Moroso catch can (shortened to meet regs) with K&N filter
    Half size radiator with alloy shrouding and electric fan
    K&N 3" cone filter
    ARP alloy heat shield
    TRD oil cap
    TRD 0.8mm headgasket
    Rest of drive train
    T50 Gearbox
    TRD Short shift
    TRD 2 way LSD
    Redline oils throughout
    Braided clutch line
    Wheels and brakes
    15X8 +10 offset rims with Toyo R88 205/50 rubber
    Wilwood Dynalight 4 pot brakes
    Wilwood brake pads
    Wilwood slotted and drilled rotors
    SS brake lines
    Nissan R33 brake booster
    Momo pedals
    Cusco brake booster stopper
    Body
    Fibreglass Front bumper, Bonnet, Front guards, Side Skirts, Rear hatch and Rear bumper
    Lexan MR10 rear hatch and side window glassing
    Racetech canvas toe hooks
    Seam welded
    Aerocatch bonnet pins
    New rear updated tail lights
    Plastic bolts used where possible
    Interior
    Flocked dash and door cards
    Digital Dash conversion
    Sabelt seats
    Bride seat rail (passenger) and custom alloy for driver
    Takata 6 point seat belts
    Innovate oil pressure and engine temp gauges
    Fuel pressure, oil pressure and water temp warning lights
    Momo steering wheel and Momo quick release hub kit
    T3 handbrake button
    USI cage padding
    Bride floor mats
    TRD gear knob
    TRD push start button
    ECU and fueling
    Vipec V44 custom looms (everything unnecessary removed)
    RCI fuel cell with level sender
    Custom surge tank and Bosch 910 pump
    Mr Gasket lift pump
    Suspension
    TRD shocks (short stroke)
    TRD springs (8kg front 6kg rear)
    Whiteline sway bars front and rear
    Tein camber plates
    T3 adjustable panhard rod
    T3 4 link adjustable rods
    T3 castor rods
    T3 Lower control arms
    T3 manual rack nolethane bushes
    175WHP running aviation fuel. Road registered
    Thats all I can think of off the top of my head!
    May 2010
    this is just PORN!
    Jul 2008
    Christchurch
    lol cheers, took a while to do it!
    Convictania
    Shit me, that is the BALLS!
    very nice.
    Thought i'd be cheeky and fix this up would love to see a Nardi wheel in that interior hehe. floor mats are SO COOL btw!
    Great car dude
    Quote Originally Posted by 4000GT View Post
    Interior
    Sabelt seats
    NARDI steering wheel and Momo quick release hub kit
    T3 handbrake button
    USI cage padding
    Bride floor mats
    TRD gear knob
    Jul 2008
    Christchurch
    Oh whats the history with Nardi on them? I have not heard about that!
    oregon
    Isn't the blacktop block the same or very similar to the silvertop? If I'm not mistaken the oilpumps are the different part that the timing tensioner mounts too.... no??
    no real biggy...
    so you are running CP 15 to 1 pistons*, Tomei rods, with Kelford 288/10mm lift cams, what are you doing for management?
    * - understand the TRD gasket is part of the overall CR
    Jul 2008
    Christchurch
    Yup very similar blocks, I have 2 hydraulic belt tensioners (new) fail, one grenaded a built motor. So we went to the silvertop block for the manual tensioner.
    Im using a Vipec V44, basically a flash Link ECU
    * and the head is skimmed
    Administrator Backyard Mechanic
    Jul 2009
    The blocks are the same, its only the oil pump which is different.
    ie. Use a silvertop oil pump and you can use a silvertop tensioner + timing belt
    use a blacktop oil pump and you can use the hydraulic tensioner + timing belt
    NIce work mate. Well done!
  1. Power FC in JZZ20 Soarer. Will it work?
    By EnFlaMEd in forum Tech and Conversions
    Last Post: 15-03-2009, 12:38 AM
  2. power windows...one of them doesn't work
    By KLR16V in forum Tech and Conversions
    Last Post: 27-11-2006, 09:18 PM
  3. Article: Torque / Work / Power
    Last Post: 02-06-2006, 02:03 PM
