What engine are you going to use? If you plan on going 4A then AE71 cross member has to be the easiest. Just cut the ends off, weld on some angle iron to strengthen the ends, drill holes and mount. Then you can use a KE70 steering column in place of the RA28 one (need to elongate the hole in the firewall for the steering column a little bit. You can just see the cut out in the pic...)
The AE71 crossmember was used for Anna's Celica (above), with the 4A engine it left heaps of room behind the engine.
http://www.toymods.org.au/forums/for...as-ra28-4.html
Bigworms build thread has pics of modifying the AE71 crossmember to fit and get the engine sitting back
http://www.toymods.org.au/forums/for...agte-ra23.html
Joel's using the same crossmember / steering column in his RA28 also,
http://www.toymods.org.au/forums/for...28-celica.html
Everything I've read about running the Nissan LCA and hubs for the S13 coilovers and Skyline brakes has resulted in excess bump steer issues. Might not be an issue if running the S13 crossmember.
Cheers.
