Results 1 to 2 of 2
Thread: Weber Fuel Fountaint in TA22
    Aug 2011
    Question Weber Fuel Fountaint in TA22
    Hey Guys,
    Just did a valve regrind gasket change on my 2T engine.. Only to rebuild it up and then try to crank it over and it wont start, keeps getting flooded and after a little bit of cranking the weber squirts like a metre high worth of fuel onto my windscreen, wtf? It's got a 32/36 Redline weber on it. I haven't set the valve clearances yet, but I doubt thats the reason why the weber is doing this. Anyone had this problem before, or know how to fix?
    Default Re: Weber Fuel Fountaint in TA22
    Hi there,
    Sounds like what happens if I put my dizzy in 180 degrees out...
    Have you double checked with cylinder 1 on Top Dead Centre and the rotor pointing at pin 1 that neither intake nor exhaust rockers are in the down position? If the engine is at TDC cylinder 1 on the firing stroke both the rockers should be up with the few thou loose play.
    Jason
  1. ta22 2T weber 32/36
    By FreaKerSea in forum Tech and Conversions
    Last Post: 04-01-2011, 06:50 PM
  2. electric fuel pump for weber - which one?
    By slapper in forum Tech and Conversions
    Last Post: 01-03-2007, 07:09 AM
