Results 16 to 20 of 20
Thread: Pinout for rear speed sensor (ABS) on 7M/1JZ/etc.. Toyotas
    Default Re: Pinout for rear speed sensor (ABS) on 7M/1JZ/etc.. Toyotas
    Quote Originally Posted by richardjeffries View Post
    Hmm?
    This is what I have.
    [ABS ECU] -> [B3 Female] -> [B3 Male Pigtail] ...................... [Speed Sensor Male Pigtail] -> [Speed Sensor Female] -> [Speed Sensor]
    So as I see it you lost / removed the following section of wiring when you did the engine conversion (as it was part of the 7MGE wiring loom) and you're trying to put it back in...
    [B3 Male Pigtail] ......<engine wiring loom>........ [Speed Sensor Male Pigtail]
    Correct?
    I'm guessing you don't have the old engine loom to simply test to find out which pin on the 'B3' plug needs to go to which pin on the speed sensor plug? That would be the best and easiest way
    Wilbo's JZA80
    Wilbo's JZZ12
    Sep 2011
    FL
    Correct the loom is completely cut up and disassembled. I'm using a stock Aristo harness, extended, and spliced my body plugs onto it. Trying to add this sensor to the loom because the Aristo doesnt accommodate it (going to run new wires)
    Thanks!
    So you can't measure / trace the wires from the 'B3' plug to the ABS speed sensor plug on the old 7M loom?
    If not why?
    Wilbo's JZA80
    Wilbo's JZZ12
    I found these in my travels...
    From the 1990 TSRM. I think that perhaps the drawn ECT connection on the diagrams from the ABS ecu to the speed sensor is incorrect...
    The pinout of the plug must be the male end as female are numbered from left to right, 1->x
    It looks like you're right with you're pinout, but I think your number of the plug might have been wrong...
    Pin #1) Signal (PSEN)
    Pin #2) Power (RR+)
    Pin #3) Ground (RR-)
    Mk3 Supra TSRM (Toyota Supra Repair Manual) Links/Downloads
    Wilbo's JZA80
    Wilbo's JZZ12
    Sep 2011
    FL
    BR50, BINGO!
    Thank you!
  1. R154 1jz abs sensor to Soarer speed sensor 2?
    By 1jz_manual_project in forum Tech and Conversions
    Last Post: 10-08-2011, 12:21 AM
  2. Speed Sensor 1JZ-GTE
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-07-2010, 08:57 AM
  3. 89420-14020 Pressure Sensor pinout/Wiring
    By irishtwincam in forum Tech and Conversions
    Last Post: 04-05-2010, 07:24 AM
  4. 1 jz vvt speed sensor
    By Demon in forum Tech and Conversions
    Last Post: 28-10-2009, 04:28 AM
  5. Speed Sensitive steering and R154 speed sensor questions
    By Bowlsclubboy in forum Tech and Conversions
    Last Post: 23-10-2007, 08:18 PM
