Bumping this back up.
These are super popular on other Toyota Forums
Spread the word on these across Toymods!
Hi Guys,
MRP Corolla coilovers + some other models listed below. We have sold over 200 sets of these, the feedback has been fantastic!. Bang for buck vs Performance & Quality these can't be beaten.
Toyota models we stock: $1350NZD delivered
Corolla AE82/92/101/111
MR2 AW11
AE85/86
Corolla AE92/101/111 With Inverted Shocks - $1750NZD delivered
Our coilovers are made in one of the top factories in Taiwan who produces for MANY leading Japanese & American branded coilovers. Their machining and technical knowledge is the best I have come across, that is why we choose to use them to build our own range of MRP coilovers.
All designs are developed in New Zealand and specifications sent to Taiwan - We review these back and forth many times until we come to an agreement on the specifications. This ensures we get proper spec'd shocks. Unlike other brands out there who use the same valving across their entire coilover range.
These will be available in street/sport shock valving
They come with a 1 year warranty with us and we will provide on going support if you end up damaging parts and need new shocks!,
I cant stress the quality these are!! and for the price!!! you wont find anything better.
Check out the pics!, performance tested since 2006 and everyone has been 100% happy with their results.
All our coilovers come with the following features:
Springs rates will be your choice
Pillow ball mounts with Japanese made bearings Front & Rear
Aluminium camber plates (Front only)
Optional rear adjustable camber plate
12 way adjustable shock absorber
Extra strong steel powder coated lower mounts
Fine threaded anodised bodies to reduce locking nuts from coming loose & corossion
1 piece designed spring perch for easy pre load adjustment
Specially designed non slip C spanners
IP Synthetic shock oil
Double O-ring seals
46mm internal piston
Mono tube (Inverted optional)
All factory brackets for brake lines & anti roll bar mount points
Shock Dyno graph
Non slip C-spanners, adjusters and shock dyno graph
AE92 AE101 AE111
AE82
AE86
AW11
Starlet EP70/82/91
Extra strong 1-piece spring perch
From 2013 all our Corolla FWD coilovers come with extended rear damper adjusters.
Meaning you don't need to remove the rear seats and tray to make changes, just a simple hole in the parcel tray for these to poke through.
Now 9AGTE 410kw atw
Now 9AGTE 410kw atw
				Ill be including info on these in my build log when mine arrivewill have to get another set for just track use later on
Is there a possibility of doing front only coilovers? IE to suit MA61 for example?
Now 9AGTE 410kw atw
What's the price for a set of inverted coilovers suit 87-89 AW11.
Also, what are the dampners like in comparison to say, Koni yellows?
The Inverted ones for the AW11 are $1375AUD Delivered.
The street valved ones are pretty similar in firmness to say stock shocks and King springs on their softest setting.
They can be turned up quite a bit stiffer as well. But they will feel much nicer than stock shocks on kings as the springs are matched to the dampers.
I cant make a direct comparison to Koni as i've never used Konis but all the Corolla track guys i've supplied these to who were on Koni Yellows said these were a huge improvement on the circuit (using our Sports valving). They also said the ride on the street was actually not too bad and soaked up bumps well.
We have heaps of Corolla guys riding on these are they are all impressed with the ride quality. We have spent years working on coilovers and getting them right.
Now 9AGTE 410kw atw
Thanks for the info Barry.
I'll have to replace my Koni's in my AW11 in the next year or so as they are fairly old, so I might just start looking at these as an alternative.
Now 9AGTE 410kw atw
				any chance of front coilovers set up for a ke20 ?
Now 9AGTE 410kw atw
				pm with cost for this setup delivered to australia sydney 2760
				PM sent re: AW11 with street valving pricing
Registering tentative interest for the AE101 Levin. I've got an old set of BC coilovers that may need an upgrade in the new year......
What is a set worth in sport valving, both standard and inverted style with the optional rear camber plates? (Heavy street use, so whatever springs you suggest, 8/6 or 6/4 front/rear?)
Now 9AGTE 410kw atw
