Results 16 to 19 of 19
Thread: suspention on a v8 conversion
    Default Re: suspention on a v8 conversion
    Quote Originally Posted by MRMOPARMAN View Post
    .....so how many toyota motors designed in the 60's make 165kw NA?
    Toyota engines of that era.... the V8 3V made 150hp and was a whisker under 3litres. Also the straight six 2litre 3M engine made 150hp. Both these engines have a much better power-to-displacement ratio than the 308.
    Anyway, this is interesting but off topic. Good luck with the build and looking forward to seeing members ride.
    seeyuzz
    river
    Junior Member Domestic Engineer Hurricane's Avatar
    ive been apart of a fuw 304/8 conversions into hilux/surf/4runners
    using the marks 4wd setup, CRS also make a adapter kit
    every one that used the stock gearbox blow it apart or broke it in time (some not even off road)
    depends on how your goin to drive it, these were not putting around most of the time.
    best gear box setup was using a R151 (i think) from a V6 surf. (i think turbo diesels might also use the same box)
    diffs were an issue when running larger tyres (like 35'') when using a 2pin open centre, the LSD 4pin centres seemed to work the best for strength.
    engine bay room was made to almost none
    all of them had cooling uses when in the bush at low speeds.
    though one wasnt to bad with the bonnet spaced up and some stuff cut out of the front, with the radiator moved forward and using the stock steel fan.
    all we did for the front suspention was to add a leaf in if needed. i think most of them just used what ever springs they had most of the time.
    i think most of them used oldman emu springs also.
    or had the Rear Up Front conversion.
    dan.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Sep 2011
    vic
    thats great advice.
    thanks heaps dan.
    off to the shop next week i hope.
    cheers.
    dave.
    have fun with it.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
  1. HELP with suspention. ta23
    By Milamber in forum Tech and Conversions
    Last Post: 06-07-2010, 05:38 PM
  2. s13 suspention ra28 q's
    By ra28sr20 in forum Tech and Conversions
    Last Post: 08-11-2007, 06:47 PM
  3. TA22 Suspention
    By frag_dog in forum Tech and Conversions
    Last Post: 06-10-2006, 02:43 PM
  4. KE,AE70 suspention set up
    By blacktop in forum Tech and Conversions
    Last Post: 14-09-2006, 06:22 PM
